boost leaking???
Old Sep 9, 2004 | 11:18 PM
WhtSvt's Avatar
Question boost leaking???
i had a post earlier in the month about my truck having all these mods and not showing the power on the dyno the only thing i can come up with is that i have boost leaking my gauge only hits ten and i have a lower 4 and upper 2. anyone have any suggestions on what to check or what could be the problem. thanks
Old Sep 9, 2004 | 11:25 PM
Suavy's Avatar
there is a few things to check. First if you have a factory gage it only goes up to 10 lb of boost. Second run your hand around the blower snout to see if you have a lot of black belt dust. If so your belt is slipping.
Then if you have a after market gage make sure the connections are not leaking.
Thats a start at least,
Suavy
Old Sep 10, 2004 | 08:39 AM
EZGZ's Avatar
If air is getting out, then it is possible to for air to sneak in.
With engine idling you have high vacum from behind the throttle plates back.
I use spray carb cleaner to direct some spray at different suspected area's. You will hear the rpm change if you find a leak.
Go slow and just work your way around all the gasket connections.
I am kinda thinking like Suavy that you have a bad guage connection.
Let us know what you find.
G
Old Sep 10, 2004 | 11:22 AM
WhtSvt's Avatar
i will get back to you guys if anyone else has any ideas let me know. thanks
Old Sep 10, 2004 | 11:33 AM
superfords's Avatar
have you checked for belt slippage?
Old Sep 10, 2004 | 12:49 PM
WhtSvt's Avatar
i have a belt tensioner
