Throttle position
Throttle position
I had my truck on the dyno saturdy and we also put auto tap on it at the time. Auto tap is reading my throttle at 16% open with the truck off and only goes to 91% open when floored. I am going right now to check my TPS voltage but am curious how it would be high when closed and low when open?
Oh and i Dynoed 381hp/475ft/lb
Weird ?
Do you have an Accu-Fab or other Single Blade Throttle Body ?
Sometimes you have to take the switch off and actually drill it a hair to give it some more adjustment (or to adjust it to where it belongs) Been there, done that.........
BTW,
you must have cake while doing it too, hehehehehehe.................
I'm sure you know how to adjust it BDAZSVT, but for those
that don't, this crappy pic I took when I did mine may help.
BTW
Nice numbers, very close to the 400/500 club
BTW,
BTW
I think that those TPS numbers are right ....
Try searching here for an old post on throttle % ... It was confirmed by a tech that the swing is not from 0-100% ...
Doug
Doug
