Billet Flow TB Question/Help
Old Sep 1, 2004 | 10:26 PM
SVTJAY's Avatar
I got a used Billet flow TB, It didn't come with the Bolts for the TPS, and it appears to not use the stock size bolts. Anyone know what size bolts i need to make this work?
Old Sep 1, 2004 | 10:40 PM
speeder's Avatar
You should be able to use the stock bolts with out any problems, I have an accufab throttle body on my truck, the holes were a little bigger than stock but it bolted on with no problems. as for the TPS, just transfer the one from your stock throttle body to the
billet flow.
Old Sep 1, 2004 | 11:03 PM
SVTJAY's Avatar
The stock bolts are to big for the Billet flow
Old Sep 1, 2004 | 11:12 PM
speeder's Avatar
are they to long ?, if so you can go to the hardware store and get some shorter bolts.
Old Sep 2, 2004 | 12:13 AM
SVTJAY's Avatar
I got some that worked.... The stock ones Diameter was to big.
Old Sep 2, 2004 | 09:16 AM
tliss's Avatar
I had to get different bolts as well. I cannot remember the thread pattern, though. I'll pull one off and go to Home Depot and see if I can figure it out. I think it was 3/4" allen bolt, but the thread pattern escapes me. I don't believe the thread pattern on the stock screw is correct either.
Tom
Old Sep 2, 2004 | 03:00 PM
SVTJAY's Avatar
Tliss,
I found some screws that worked, thanks for your help
