will this grinder work on the Brake Calipers??
Old Aug 25, 2004 | 10:15 AM
halcyon's Avatar
Question will this grinder work on the Brake Calipers??
Im going to grind down the rear calipers to fit some 15x10's.
Ive never done anything like this, but will this grider work:
http://cgi.ebay.com/ws/eBayISAPI.dll...320451658&rd=1
I will have some help too.
Old Aug 25, 2004 | 10:41 AM
Ed753's Avatar
Thumbs down You are going to do what!?
That is not a good idea, brake calipers are thick and heavy for a reason, a typical caliper is designed to be as light and use the least amount of material possible, while maintaining durability. If they could make them smaller and thinner they would. Your caliper will do one of two things and maybe both. Flex, which will cause a mushy pedal, and eventually just snap! I've seen it we have a lab at our complex that tests casting, it does nothing by apply and release. Quite often a BOOM is heard......too thin it snapped!
The only exception is if you are just going to take off some small casting mold dimples or seams, that I'd recommend lightly file.
You've been warned!
Old Aug 25, 2004 | 10:51 AM
LightninSVT's Avatar
I think Chris (superfords) did a whole write up, or at least pictures of the process. Do a quick search or maybe he'll chime in here
Jon
Old Aug 25, 2004 | 11:03 AM
halcyon's Avatar
I saw his post, had lots of great pics.
