Drive Shaft Loop Installed (pics)
Competition Engineering loop.
20 minutes max to install. Fit EXACTLY between the frame rails.
Loop is removable so you don't have to remove the drive shaft to install.
Black powder coat, all hardware included, PERFECT fit. No holes to drill, etc.
Very nice piece. I wish all aftermarket parts for our trucks fit this well.
Looks like a very nice Piece, and tit install
Isn't it crazy that I can say tit, but not ***** cat,
I have the PSP set up, also an easy install, and perfect fit.
Not sure I've ever seen that one before, I like it, I like it...
Re: Drive Shaft Loop Installed (pics)
Originally posted by whitebolt01
B-Man,
did you have to remove the driveshaft?
B-Man,
BTW:Nice set up, I think I might have to get one just cause it is so easy to install
later
brian
BTW...
B & I both replaced the washers that came w/ the kits this weekend w/ some grade 8 ones.
The ones they supplied became distorted after being tightened down...found out when it was pulled off to install the magnaflow on my L.
Otherwise....like stated....easiest part to install yet.
