Pls help guys My 2000 Lwon't start
Old Aug 20, 2004 | 07:34 PM
johnathanh's Avatar
Unhappy Pls help guys My 2000 Lwon't start
Hi guys how's it going?
Well my L won't start It would turn over but won't start
The batery is new and it still won't start and the theft light is blinking realy fast when the key is in start mode
My L is a 2000 it is completely stock it has stock chip
What could this problem be???
Please help me guys
Tanks a million!!!
johnathan
Old Aug 20, 2004 | 07:38 PM
olefafl's Avatar
Re: Pls help guys My 2000 Lwon't start
johnathan
You tripped the PATS. Time for a locksmith, or a trip to the dealer.
The keys need to be reprogramed.
Old Aug 20, 2004 | 07:42 PM
johnathanh's Avatar
Re: Re: Pls help guys My 2000 Lwon't start
The key program guy checked the key but he told me that the key is fine no need for reprogramming
And now im wondering what it could be
Thanks olefafl
Old Aug 20, 2004 | 07:48 PM
olefafl's Avatar
"theft light is blinking realy fast"
https://www.f150online.com/forums/sh...hreadid=139164
Old Aug 20, 2004 | 09:40 PM
zbornac's Avatar
Check your fuel pumps. You may have blown of the hoses. It is a semi common occurance in the 99/00s. Had mine come off on the freeway last summer. More than likely you'll have to just reconnect the hose, but there is a chance that the pump itself could be bad (mine was).
If you do end up needing new pumps you might as well buy some bigger ones as they are cheaper than getting the Ford replacement. I was lucky enough that mine happend the day after my warranty was out, but they sqeezed me in. Invoice was around $800 plus a $200 flatbed tow.............
Good luck, I hope it is something more simpler like PATS.
-Kimball
Old Aug 20, 2004 | 11:55 PM
Suavy's Avatar
My key reader went bad in my steering colum and cause a simular condition.
Suavy
Old Aug 21, 2004 | 03:05 PM
johnathanh's Avatar
ttt
Old Oct 22, 2004 | 09:40 PM
johnathanh's Avatar
The L still won't start
Checked everything
thanks guys
Old Oct 22, 2004 | 09:44 PM
Don's Bolt's Avatar
Also check the fuse for the fuel pump
Old Oct 22, 2004 | 09:48 PM
johnathanh's Avatar
checked that too everything seems to be ok
Thanks don
Old Oct 22, 2004 | 09:53 PM
Don's Bolt's Avatar
Disconect the battery go have a beer, and try it later.
Sometimes that will reset the pats system.
Old Oct 22, 2004 | 10:00 PM
johnathanh's Avatar
did that too but didn't work
thanks don it think i will take it to ford
Johnathan
Old Oct 22, 2004 | 10:20 PM
Don's Bolt's Avatar
Johnathan
Well in that case get a bottle of tequilla and drink yourself silly, wish I could help you but if the other guys ideas didn't work I have no idea.
Old Oct 23, 2004 | 01:16 AM
Redlightn 02's Avatar
Please keep us posted................
Old Oct 23, 2004 | 02:03 AM
LatemodelRacer2's Avatar
check the 30 amp fuse in the fuse box under the hood. It is the one closest to the firewall. Mine blew in the burnout box at the track and that was what it did. Wouldnt start.....replaced the 30 amp fuse and it started right up. Theft light was blinking like you stated
