Intercooler switch
Old Aug 20, 2004 | 04:40 PM
JimJr's Avatar
Intercooler switch
Anyone have a pic of where they spliced the line in for the intercooler pump switch? I know its Pin 70 on the PCM and it white with orange stripes but where did you splice the line in. I can find the right wire and i dont know which pin is Pin 70.
Old Aug 20, 2004 | 06:50 PM
Suavy's Avatar
I did the safe thing and just spliced it at the pump and ran the wires in a wire loom.
Suavy
Old Aug 20, 2004 | 07:02 PM
JimJr's Avatar
how do you do it that way
Old Aug 20, 2004 | 07:04 PM
Fast Gator's Avatar
Suavy
I went an even easier way...............
I had Shawn do mine
Old Aug 20, 2004 | 07:32 PM
olefafl's Avatar
You can also do it like this.
No cutting or splicing.
Old Aug 20, 2004 | 08:30 PM
JimJr's Avatar
does that keep it on full time?
Old Aug 20, 2004 | 11:35 PM
olefafl's Avatar
Yes, it will run till you take the jumper out. All the jumper is doing is making the same connection that the relay does.
Old Aug 20, 2004 | 11:46 PM
bglanden's Avatar
Will that work on an 03?
Old Aug 21, 2004 | 12:23 AM
JimJr's Avatar
I have a 03. I'm gonna give it a try tomorow. Do you know what box that is? what relay
Old Aug 21, 2004 | 12:41 AM
bglanden's Avatar
I figured you would be in New Hampshire tonight!
Old Aug 21, 2004 | 01:22 AM
JimJr's Avatar
why would i be there?
Old Aug 21, 2004 | 01:23 AM
bglanden's Avatar
Lightning's!
Old Aug 21, 2004 | 01:50 AM
jerzey storm's Avatar
just jump into the white wire going into the intercooler pump run the wire and hook up a switch from the wire to the battery , that simple, took me 10 minutes and about 7 dollars.
Old Aug 21, 2004 | 08:35 AM
olefafl's Avatar
It's the box under the hood, driver's side fender. This is an '01; not sure if they changed anything for the other years.
Why cut, hack and spend all that money? Also, you don't have to worry about your dealer or anyone else finding it - you just pull it out and you're done.
Old Aug 21, 2004 | 11:47 AM
JimJr's Avatar
Originally posted by bglanden
Lightning's!
Thats a little wierd that you know where i live somehow........stalker
