Max Timing Question
Old Aug 18, 2004 | 06:42 PM
JimJr's Avatar
Max Timing Question
I did a search and found nothing for this.
I just got a new tune for a 6lb lower and i asked for it to be a lil more aggressive then the last one i had(4lb 17 degrees timing) and i now have one for 18 degrees timing. I was just curious as to what the most timing someones running safely is / whats the limit ? Thanks Jim
6lb
Predator
JLP Ram Air
Old Aug 18, 2004 | 06:50 PM
AMP's Avatar
AMP
Jim, use the Predator and advance your timing as much as humanly possible. You're truck will be really fast for a minute!
Old Aug 18, 2004 | 06:56 PM
JimJr's Avatar
god i hate you!
How did the plugs look?
Old Aug 18, 2004 | 07:14 PM
halflife's Avatar
not a tuner, but I think around 20 on pump gas
Old Aug 18, 2004 | 07:22 PM
AMP's Avatar
AMP
the plugs looked brand new. I still feel better having the 22's, but that definately wasn't the problem. Someone smarter than me thinks the computer "freaked out" when it read the MAF reading and it was higher than it had ever been. Just disconnecting the battery should reset everything. It's been running better than ever... no problems.
I'm still working on getting a tune
I just contacted a different vendor today, so we'll see if they can send me a tune in less than 2 weeks!
call me before I spend the money I owe you!
Old Aug 18, 2004 | 07:24 PM
AMP's Avatar
AMP
p.s.
I like the title of your post, so from now on your nickname will be:
MAX TIMING
Old Aug 18, 2004 | 07:37 PM
Neal's Avatar
HI!... I'm a highly modded N/A 5.4, but MIKE T has my max timing set at 26 degree's. No problems here. On a totally different tune, I went 3 years on almost 30 degree's. Knock sensor data shows it wasn't knocking.
Old Aug 18, 2004 | 09:33 PM
JimJr's Avatar
screw that "smarter person". i doubt he's even really ASE certified. Call RWTD. Dont worry about the money.....i know where you live.
Old Aug 18, 2004 | 09:34 PM
JimJr's Avatar
p.s.
MAX TIMING
better tell mini me he's now Mini Max Timing.
Old Aug 19, 2004 | 12:51 AM
Blown347Hatch's Avatar
16* here.
Old Aug 19, 2004 | 01:59 AM
birdy111's Avatar
so then what's the timing set to from the factory?
Old Aug 19, 2004 | 02:51 AM
afchad's Avatar
16 degrees here....18 on race tune with 6lb lower and 1lb upper
Old Aug 19, 2004 | 03:39 AM
grinomyte's Avatar
most you can do safely?
360 degress
Old Aug 19, 2004 | 08:43 AM
Rob_02Lightning's Avatar
My LOW TIMING PROGRAM (was suppose to be 16 degrees for the Nitrous) turned out to be 19 degree's when Sal Dyno'd it,
WOO HOO......
My 24/7 street program was suppose to be 19 degrees,
I haven't Dyno'd with that Program yet, but we're guessing it's
going to be well over 20, YIP YIP YIPPY YIA..........
I've been driving it, racing it, and killing on those two programs
WELL OVER A YEAR NOW. Making a ton of power and having no prob's at all, (and surly no Detonation), even on pump gas..........
Cold Plugs, throwing a ton of fuel at it, and Multi Spark
DO HELP ME THOUGH
Old Aug 19, 2004 | 07:08 PM
AMP's Avatar
AMP
SSSSHHHHHHHHHH!
He'll hear you!
