To overdrive or not to over drive? that is the question
It doesn't matter. Overdrive won't engage at WOT until after 135. Had a problem with mine engaging on the track...but I had tranny problems. Mechanic said unless you are trapping 135 or better...not to worry.
ontario
I live in colorado where there are lots of hills and curves. Even in town.
When the speed limit is 45 I turn off my overdrive to keep it from always downshifting.
My truck shifts to OD around 40 MPH. I hate that. If I chip it I will have that changed to 50
My work truck is a 00 Ford powerstroke and it is the same way.
I recently put in a power valve and that firmed up the shifting but I still turn off the OD in town.
You will have to do the Kilo MPH conversion. I am to tired.
I don't know if it hurts the tranny but I like it to slow me down when I am going down hills and over the speed limit. Other wise I would be on the brakes all the time.
I Hope this is the kind of information you are asking for.
Think about it the truck tops out at 143 or so - if he was right then OD is only needed for the last 8 mph ???
Doug
I shift into OD about 150 feet from the 1/4 ...
About 101 or so ...
About 101 or so ...
About 101 or so ...
About 101 or so ...
I was told to only use O/D for cruising and not for any kind of racing or hard load bearing activities, because O/D is the weak link in these trannies and it will be the first thing to go. So there for mine always goes off when I race.
I thought the weak link was that intermideate clutch pack.
It feels like a a 5 speed. There is that little down shift if you even give it the slightes gas to speed up.
Maybe I should have stopped
sooner.
sooner.
sooner.
sooner.
If you want to sound like a 13 year old "l33t" jackhole, by all means go ahead.
But, if it takes too much of your time to type "you" instead of "u" and forming a coherent sentence structure, maybe you can find another board to post on.
Originally posted by clonetek
I use my overdrive like, in the transmission, and stuff... or something.
Does anybody speak Jive on here?!? We need a translator. STAT!
:I'll try to help out ...
1. u = F150 members
2. or u =
Originally posted by Ontario Canada
when u race u dont use it?
