Vibration
Old Aug 14, 2004 | 05:57 PM
whitebolt01's Avatar
Vibration
I have a slight vibration at around 65-72 mph and was wondering what can be done to fix it. It fells like it might be the rearend?
Any suggestions are appreciated.
Thanks,
Simon
Old Aug 14, 2004 | 06:31 PM
03LightninRocks's Avatar
The three things I would look at first are...in this order...
Rear wheels/tires for obvious defects and for balancing
Pinion angle if you have done any height mods on your truck
Drive shaft...have a dealer check to see that it is properly balanced.
Rocks
Old Aug 14, 2004 | 06:48 PM
I do have drop shackles. How do you make the pinion angle equal to stock?
Old Aug 14, 2004 | 07:06 PM
kerno's Avatar
It is fairly easy to fix. Go to:
http://www.djmsuspension.com/Product...inionShims.htm
If all you've done is the drop shackles, the lowest angle should fix the problem. Some of the Lightnings, like the 2003 and 2004's come with a shim as a part of the pring pack.
Old Aug 14, 2004 | 07:22 PM
I flipped the shims but it still vibrates
Old Aug 14, 2004 | 08:07 PM
'02silver's Avatar
I thought only the 03s & 04s have shims not an 01.Try putting the stock shackles back in. If that solves the problem then you need to get different shims.
Old Aug 14, 2004 | 08:16 PM
LightningGuy's Avatar
You are correct. You only need to shim the 03/04 with the "revised" rear suspension, not the model years before that.
Old Aug 14, 2004 | 11:10 PM
EZGZ's Avatar
The August issue of Hot Rod magazine page 142 talks about Driveshaf u-joint angles.
For general street use, the sum of the trans ouput-shaft angle and rearend pinion-shaft angle should total 180 degrees (+ or - 2 degrees), and on high-speed automotive driveshafts, the angle of offset between the driveshaft and U-joints needs to be between 1 and 5 degrees. Shim the engine/trans mounts or slighty rotate the rearend pinion nose as needed to accomplish this.
Good vibrations is no vibrations
Old Aug 15, 2004 | 12:48 AM
FunFord's Avatar
Registered User
My truck does the same thing and its all stock.
Old Aug 15, 2004 | 01:11 AM
I suppose I got lucky. My 2003 didn't need any pinion adjustment.
I only did the 2" shackles...maybe that was not enough to create problems.
Here is a link to a thread I found pretty informative about pinion angles.
http://www.nloc.net/forum/showthread...t=pinion+angle
Rocks
Old Aug 15, 2004 | 11:20 AM
Does anyone know the correct pinion angle for the 04 lihgtnings?
Thanks,
Simon
Old Aug 15, 2004 | 12:14 PM
Thanks,
Simon
Here...check out this one. http://www.nloc.net/forum/showthread...t=pinion+angle
I am not trying to be a smart **** here, but doing a search on pinion angles at NLOC turned up a butt load of info.
Rocks
Old Aug 15, 2004 | 12:26 PM
So should I buy different shims and use them and see what happens?
Thanks,
Simon
Old Aug 15, 2004 | 12:31 PM
Thanks,
Simon
You should measure your pinion angles to see if that is even the problem.
Have you clicked on the links I posted?????? All the learning you need is in them.
The last link I posted has some excellent info.........
Old Aug 15, 2004 | 12:50 PM
I did read them, and from what I read the pinion angle should be 5.7 degrees. So when I measure it and find out what it is I will post my results.
Thanks,
Simon
