Cervinis Louvered Hood
Old Aug 8, 2004 | 11:57 AM
Txoutlaw's Avatar
Question Cervinis Louvered Hood
Anyone running this hood?
I really like the way it looks especially with the windshield washer squirt nozzles relocated.
It resembles the one that BMWBig6 designed.
Old Aug 8, 2004 | 12:07 PM
Krix330cic(NJ)'s Avatar
Too bad they cant do that on the cowl hoods...
Old Aug 8, 2004 | 12:09 PM
Txoutlaw's Avatar
Aint that the truth!!! That would be one bad a$$ looking hood!
Old Aug 8, 2004 | 12:27 PM
Blown5Pnt4's Avatar
I have a question about it though....is it actually functional, like with the slits going all the way thru to allow heat to escape ?? or are they filled in and you have to cut them yourself.....if it is indeed fully functional, I WANT ONE. Imagine how much louder the blower whine would be.
Josh
Old Aug 8, 2004 | 01:19 PM
Txoutlaw's Avatar
I emailed them to see if the louvers are actually open to the engine bay. It doesn't say one way or the other on their website (which probably means they aren't). I'm anxious to hear back from them and I will post their answer once I receive it.
Old Aug 8, 2004 | 04:05 PM
superfords's Avatar
I have never seen that hood, it looks pretty awesome to me. is that an actual photo or a photoshop?
I wasn't aware that cervini's had a new hood available.
I definately can't afford one.
but I do want to know...
1. is it really available?
2. how much does it cost?
3. how much does it weigh?
4. are the heat extractors functional?
later,
chris
Old Aug 8, 2004 | 04:09 PM
Odin's Wrath's Avatar
later,
chris
https://www.cervinis.com/shop.html
Old Aug 8, 2004 | 07:07 PM
superfords's Avatar
OK, so:
1. it's available
2. for $439.
that just leaves 3 and 4
Old Aug 8, 2004 | 11:05 PM
99BlkLitng's Avatar
I went to their site and did not see anything about that hood, only the cowl and ram air hood. I really like the looks of this hood and if functional like others I would be interested in it.
Later
Damon
Old Aug 8, 2004 | 11:18 PM
Redlightn 02's Avatar
97-03 F-150 Louvered Hood - Part #1160 __
$439.00
_ _
Finished underside liner can be painted for show quality appearance. Windshield washer squirters are relocated and hidden under the hood.
Old Aug 9, 2004 | 10:15 AM
TampaBlack99's Avatar
I bet there as functional as the ram air hood they sell.
They would have to make drip trays for them work and not get water all over the engine/coil packs.
The louvers would have to be located farther forward to prevent soaking the coilpacks/engine. I have been working on this problem for a few months with my louvered hood I am trying to fab.
Old Aug 9, 2004 | 06:07 PM
eposey's Avatar
Superfords...
Their hoods are fiberglass so it shouldn't be any heavier than the stocker.
I also doubt it is functional for $439.
Old Aug 9, 2004 | 06:18 PM
superfords's Avatar
actually from what I've been told the fiberglass Cervini's cowl hood is quite a bit heavier than the stock Ford aluminum hood.
that's why I was curious to know about this one.
frankly, on a 4900 lb truck a couple 10 or 20 lbs doesn't make a chit of difference.
but I still just hate the idea of taking off a lightweight part to add a heavier one for the sake of looks alone.
just my .02
later,
chris
Old Aug 9, 2004 | 06:49 PM
halflife's Avatar
I have a civic and they make them for it. The hood comes witha peice of something to attach to the underside of the hood to prevent water from entering. So you just have to get out of the car in the pooring rain, install the cover and then go on your merry way all soaking wet, but you engine will be cooler
Old Aug 9, 2004 | 08:06 PM
Wrong, its quite a bit heavier then the stocker.... stocker was light as a feather compared to my Cervinies Cowl.
