Passanger Seat broke help!
Old Aug 5, 2004 | 09:47 PM
1fst54's Avatar
Passanger seat will not go back to the correct position. It will not lock in the up right position. Right now it is folded and I can't see the passanger sided mirror. Can any help on what i need to look for?
Old Aug 5, 2004 | 09:50 PM
H30rat's Avatar
happened to mine a few times too....slide the bench way forward, then push seat back all the way until it engages again. might have to mess with the lever or something, i forget.
Old Aug 5, 2004 | 10:46 PM
afchad's Avatar
My truck had to go in four seperate times for the same thing. Three times with passenger seat and once with driver seat. They finally showed me how to fix it. Slide seat all the way forward, and the recline all the way till it clicks. It should lock back.
Old Aug 6, 2004 | 07:25 AM
Rob_02Lightning's Avatar
Ya mines a little tricky too after the last time it came in and out at the track. Look under there and you'll see the teeth are prob not lining up, sometimes if you simply loosing the bolts and **** it
CAN I SAY **** ??? it should fall back in place and lock in
Old Aug 6, 2004 | 07:26 AM
Gee I guess I can't
C.ock
Old Aug 6, 2004 | 11:12 AM
clonetek's Avatar
Pull the seat all the way forward & push the top part back till it clicks. You may have to "slam" the top part back to make it grab.
Old Aug 6, 2004 | 02:38 PM
1fst54's Avatar
Sorry for such a slow response tried the first person response which seems to be everyone elses and it worked Thank you to all that chimed in and helped.
