exhaust pressure too high?
Hey guys,
I've got the mods listed below. Anyways, i just got a magnum powers charger and got to talking to the boys at JDM. They seem to think i need to scrap the stock exhaust and open it up to help relieve the pressure on my stock block due to the restrictive exhaust. The mods and tune i was going for should put me at about 450 horse (hopefully). I don't want to go past 450 for now but if i do ehaust i think it will take me closer to 500. My questions are:
1. do you think running aftermarket exhaust that creates more horsepower will be safer for my stock block than a restrictive exhaust with less horsepower?
2. By opening up the exhaust do i only need to take care of the cats or are the exhaust manifolds pretty restrictive as well.
i was thinking of possibly running a 2# instead of the 4# lower since the magnum comes with a 2.70 upper then putting on the exhaust and that might put me close to 450?
What do you guys think? Thanks for helping me out. You all seem to be able to shed light on all problems. Thanks.
Mods are: (2000 lightning)
Bts trans, PI converter, 90 mm maf, magnum charger,
4lb lower(currently), boost bypass, CAI, 160 stat, tr-6's, e-fan, 2002 intake and intercooler, predator, l&s separator, t-bars
Sure you'll see higher HP numbers..
However I think it comes down to how you use the truck. If it's a only a cruiser & 1/4 mile drag toy? Then place your order.
If it's a daily driver and/or a 1/8th mile toy? Then you'll wanna keep that low end torque offered by the *somewhat* restrictive stock exhaust.
Rich
Rich
This is a very appropriate question for me as well.
I am putting a MP on mine, as well as a 4lb lower. I was thinking about ditching all four cats to lose a bit of the restriction. Anybody have sound clips of factory manifolds, no cats, and a magnaflow catback?
With a 4lb lower and the MP blower which comes with a 2.7" upper, how much boost will we get with stock manifolds?
all engines are air pumps.
the more air that it can pump through, the more power it will make.
So if the flow is bottled necked somewhere, then you are losing power.
open up the exhaust will allow more air to flow.
Originally posted by FooFur
You wont regret getting a full exhuast system on your L.
kooks + bassani > kooks + magnaflow
my tuner knows the owner of bassani so I'm #2 in line.
its a 30-45 day wait but I hear it's supposed to be wild.
Everyone pray it works as well as I hear
Really the question i need you guys to help me with is:
Am i more likely to break my stock block with 450 horsepower and a restrictive exhaust then i am with 500 horsepower and an opened up exhaust.
JDM has told me that the pressure exerted on the rods due to the restriction of my stock exhaust is too high and must be remedied imediately. Like i said before i would like to be sitting at around 450 horsepower with a conservative tune. Just to be safe so the stock block can live a little longer. Thanks guys for all your help.
Oh yeah and if i do the exhaust i was thinking of just gutting the cat and installing a new muffler and leaving the exhaust manifolds as long as they are efficient enough. Do you think the stock exhaust tubing is of sufficient diameter to support 450 or 500 horsepower. Thanks again.
Your combustion & exhaust gas temps would be lower & the heads would be able to flow a bit better on the top end.
As far as added pressure... the amount of additional "pressure" is small in comparison to things like detonation. Which....? may be what your vendor is trying to tell you? But in a generic manner. (open exhaust would be a bit easier in preventing detonation)
BTW, the free flowing exhaust comes mostly from the high flow cats.
Rich
Originally posted by wydopnthrtl
...BTW, the free flowing exhaust comes mostly from the high flow cats.
Rich
Rich
Anybody got any exhaust clips of stock manifolds and no cats?
The downside to the full exhaust is the noise and the dollars spent.
The upside is lower boost pressure and more HP.
I already had several mods on my truck when I went from a single Magnaflow to a full exhaust with a single Magnaflow. It felt noticabily stronger (more responsive) when I stepped on the gas a little at lower RPM cruising speeds. My 1/8 mile and 1/4 mile ET's along with MPH were better. This is fact not opinion.
How could it not be safer on a stock block? It should lower your boost pressure by 1 to 1 1/2 pounds. This would make you less likely to detonate and less likely to stretch the factory (torque to yield) head bolts lifting a head.
I'm sure your tuner doesn't mind selling you a full exhaust system but what he is telling you is not BS.
but keep in mind it's all relative to many other things. The tune being numero uno.
BTW: 1/8mile speeds are not a mesurement of low rpm torque. And that is a FACT.
Rich
Mine is a daily driver that is over 4 years old with 53,000 miles. The full exhaust has been on for over 2 years. There were no weak spots that could be felt in daily driving. It felt stronger EVERYWHERE. This is a FACT.
BTW, You mentioned daily driving and 1/8 being a negative. I was just responding with my experiences.
Peace
Peace
