The L died twice on the interstate, help?
Old Aug 2, 2004 | 03:36 PM
78f1hundo's Avatar
Ok here is the situation....
I was driving on the interstate and it was a little warm out upper 90's, so I kicked the air on going about 60 mph's. Then 5 seconds later the truck shut off. The gauges went dead, engine service light soon came on, and the mile readout did this (-----------). So I coasted over and shut the L off. Waited 10 seconds and she started up fine and drove perfect.
Then got back on the interstate, and the L almost died again.
I don't know what the deal is...
I get on the L hard it performs great. This is just your normal interstate driving. Overdrive on and rpm's range 1900-2300.
Any help would be great?
My mods are....
JDM Silverbullet catback
JDM Electric Fan kit w/ Cobra R waterpump
PSP Cold air intake system
PSP 4lb. lower
REM Smooth intake tube
SVO Single Blade Throttle Body
Apten Ported Eaton
Apten Smooth upper intake
90 mm Mass Air
Autologic 4-way chip
Dyno tuned By Sal @ PSP
Denso Iridum 22's
Old Aug 2, 2004 | 03:38 PM
easterisland's Avatar
Maybe the chip is loose?
Old Aug 2, 2004 | 03:47 PM
blackbeast 99's Avatar
Sounds like your chip could have a loose connection to your factory PCM.
Old Aug 2, 2004 | 04:06 PM
78f1hundo's Avatar
I thought that it might be that.
I never taped it down after the Dyno tune.
I think I just need to take the computer out and tape her down good.
Thanks for the help.
Old Aug 2, 2004 | 04:30 PM
ben_g99's Avatar
That's Lesson #1 when it comes to chip tuning!
Chip - $250 +
2 Rolls of Duct Tape - $10
Never having to worry! Priceless!
Old Aug 2, 2004 | 04:31 PM
SVT_KY's Avatar
Double fold back the Duck Tape on the cab side of the ECM
and you can get it in and out from the cab without taking
the ECM out. < Grin >
Old Aug 2, 2004 | 04:37 PM
l-menace's Avatar
mine did hte exact same thing...
I thought it was a chip, but at the time I was running off the reflashed PCM...
Never did it again.
no idea what happened
Old Aug 2, 2004 | 05:28 PM
Fast Gator's Avatar
Re: The L died twice on the interstate, help?
Thats a dead giveaway...........loose chip/bad connection
Old Aug 2, 2004 | 05:41 PM
LIGHTNINROD's Avatar
I hope I'm wrong but it may not be a loose chip in that pushing it in(and taping it) will fix it. I had a similar problem and it was the chip in that its contacts were not gripping the PCM's board tightly enough. Taking the chip out and/oe replacing it with another chip 'fixed' my L but of course, the chip still had a problem..............
Dan
Old Aug 2, 2004 | 09:24 PM
DEIMATT's Avatar
Steve you got corn in your side pipes!!?? HEE HEE HEEE
GO CATS!! LMAO
