NGK TR6's or NGK BR7's?
NGK TR6's or NGK BR7EF's?
It's time for me to change plugs again. I know it's an ongoing debate, however, I know I am going to stick with NGK plugs.
The main question is whether to go one or two ranges colder. My mods are; 4lb lower, JDM Flipchip (a/f = high 11's), E-Fan, Cobra Waterpump, CAI, Magnaflow Catback.
Some suggest with my mods to stay stock for heat range. I want at least one range colder, but have heard that the BR7's work well too, and they are two ranges colder.
I am currently running TR5's and they do not seem to last worth a damn.
So, One range colder or two? Let's hear opinions.
Thanks!
Thanks!
br-7.
cooler plug = less change od denotation.
anything over a 3# pulley = Br-7
Stock to a 3# = tr-6
I have 8 tr-6 brand new in the box, never opened if you are interested.
Originally posted by l-menace
br-7.
br-7.
(*unless you have an SCT chip*)
TR6
Edit:
Jeff,
The Brisk are working great so far in my truck with a #5 lower and ported blower. I pulled one last night and looked at the burn. It looked perfect.
Edit:
Jeff,
Originally posted by LTNBOLT
TR6
Edit:
Jeff,
TR6
Edit:
Jeff,
but you'll have a crappy idle if you usde br-7 becuase they are 2 ranges cooler than stock plugs.
I have always been told that the TR-6's are good up to 6 lb pulley.
Also that the BRZ's are to cold of a plug for any thing under 18 lb of boost.
i run 18 lb of boost daily and have run TR - 6's and Denso IT-22's I have also burned up both types before. Believe it or not! I blew 3 Densos Sat and replaced them with a set of Chapions one stage colder than factory. I must also say that my truck has never idled or run so smoth before now. Go figure.
Suavy
Suavy
BR7EF's here..I had a bout 15000 or so on these and experienced a stutter...one had a ground gone..not that this means the plugs are no good. All the others looked good...only a thousanth gap over install...
Thje iidle is nothing to worry about...a bit rougher than stock..but hey...are you stock?
