Bad PCM
Old Jul 20, 2004 | 01:25 PM
Learo2000GT's Avatar
Bad PCM
My L is not running good at all. When it goes into the boost(high RPM's) it just dies, it is boosting up but laggs and back fires. Changed plugs and fuel filter. Took it into the dealer, and they said the PCM is shot and they are getting me a new one. They said the PCM is not allowing the boost to go into the engine. Anyone ever here of this???? Runs fine when out of the boost...
just curious anyone else have a PCM go south......
Old Jul 20, 2004 | 01:39 PM
l-menace's Avatar
wait a second.
tell them to reflash it and see what that does.
if the PCM goes bad, then it doesn't work at all! not periodically,
tell them to reflash it.
Old Jul 20, 2004 | 01:41 PM
OK will try that..... does not make any sence to me either.....
Doug
Old Jul 20, 2004 | 01:59 PM
tommylightning's Avatar
What plugs are you using? I have seen this using non resistor plugs.
Old Jul 20, 2004 | 02:40 PM
l-menace's Avatar
what if you did the boost bypass mod
that way the computer can do whatever it wants and there is still boost
Old Jul 20, 2004 | 04:48 PM
well tried the boost bypass mod and made no differance. Plugs are the NGK TR6.. so good to go there. Called the dealer and they said that parts of the computer can go bad...... you got me.......
Old Jul 20, 2004 | 09:03 PM
01 XLT Sport's Avatar
That is true that part of the PCM can go bad. It is nothing more then IC chips that basically have inputs and outputs. You could have a chip where some of the outputs and/or inputs are faulty while others are just fine. The software would be fine as well. It would be like walking into your home and 4 of your 6 light switches work and the other two don’t that’s a basic IC chip…
Old Jul 21, 2004 | 12:45 AM
BigFan's Avatar
Originally posted by l-menace
wait a second.
Wow your a law student and a Dealer Tech
As Stated above part of the circuit board can go bad.
Old Jul 21, 2004 | 05:18 AM
deputylightning's Avatar
how much is reflashing and who can do it and is there any was to tell if any parts in the pcm are bad like does it throw a code or something. if a part of is bad and not the whole thing will reflashing fix it or do you need a new one and how much are they and do you have to buy it from ford
Old Jul 21, 2004 | 12:06 PM
The dealer should have some type of test they can run on the PCM to insure all inputs and outputs are working correctly, or to just tell them the PCM is working with no faulty hardware and/or software.
