Clunk Washer Install Will Not Affect Alingment
The clunk washers are set up for dead center bolt location.
If yours are centered then no problem. You can take the nut side off for a look see without hurting a thing.
I just installed mine today and the stock was not perfectly centered so I am going to get the Cam Bolt kit and install them before I do anymore alignment work.
If you have the stock shim pack instead of the cam bolts the aligment shop will tac on another $100.
After that they and tweak as needed.
