O so close to 12s
Old Jul 2, 2004 | 11:08 PM
ByByBird's Avatar
O so close to 12s
13.08 @ 104.77 w/ 1.93 60ft
Temp:80
Humidity: 68%
Baro: 29.99
Mods..4#, JL intake, JL dyno tuned predator, Denso plugs.
I'm so close I can
Old Jul 2, 2004 | 11:32 PM
Rob_02Lightning's Avatar
Re: O so close to 12s
Temp:80
Humidity: 68%
Baro: 29.99
I'm so close I can
CELEBRATE
See where you wrote Temp 80
Make that say 55-65 and you can take up to a full 1/2 second off that ET. CONGRATS BRO, don't loose sleep over 9/100th's of a sec.
YOUR IN The weather just wasn't right.......
Old Jul 2, 2004 | 11:36 PM
SlowSVT95's Avatar
Almosssssssst
Old Jul 2, 2004 | 11:59 PM
ByByBird's Avatar
You guys are a total riot over here!!
The supercooler, FTVB and "getto scoupe air" will be going on in the next month. I'm hoping to get a consistant 12.8 out of the L on radials and maybe Mid 12s with slicks and traction bars
Old Jul 3, 2004 | 12:31 AM
Sounds very do-able to me, GO GET UM
I have multi 12.7's + 8's with just the 4lbr, (no juice of course)
it's all about the air temp, and proper cool down
Old Jul 3, 2004 | 12:44 AM
SlowSVT95's Avatar
Don't listen to Rob... Everything is do-able to him.
Old Jul 3, 2004 | 12:54 AM
LightningToGo's Avatar
Old Jul 3, 2004 | 01:57 AM
ND4SPD's Avatar
nice times bro, how much boost are you seeing
Old Jul 3, 2004 | 02:41 AM
hslightnin's Avatar
Temp:80
Humidity: 68%
Baro: 29.99
I'm so close I can
well this winter me and you both need to make it
i went 13.04
got me swoll
Old Jul 3, 2004 | 04:48 AM
teamsvt2002's Avatar
Temp:80
Humidity: 68%
Baro: 29.99
I'm so close I can
You feel bad not getting into the 12's yet with those mods. I haven't been able to break into the 12's just yet with the following mods:
2 lbs. upper
4 lbs. lower
Ported Eaton
Long Tube Headers with full exhaust/ X pipe - no cats
P. Spacer
Lakewood traction bars
Drag Nittos
SB/TB
NGK's 6
JLP Tuned Diablo Delta Chip
Cold Air Intake
Heat Exchanger
My only excuse that I have is that I haven't gone to the track on cold weather. It seems that everytime I go its on the 90's. The only time I gone on cold weather I broke a 13.1 with half of my mods on cold weather on 26 inch slick with stock 3.73 gears on a 02 L.
Last time I went I made a 13.2 @ 106 with a 1.9 at the 60 ft
The way I see it L's don't run good on hot weather. The way I see it I should be running in the 12.5 range on the cold weather. But cold weather on south Texas in not that common.
Old Jul 3, 2004 | 10:34 AM
SVT_KY's Avatar
I actually have a 13.003 timeslip in my pursuit of the
12 second club ... Can't get much closer ...
Just wait til the fall ...
Old Jul 3, 2004 | 07:09 PM
SVT F15O's Avatar
Re: Re: O so close to 12s
2 lbs. upper
4 lbs. lower
Ported Eaton
P. Spacer
Drag Nittos
SB/TB
NGK's 6
Cold Air Intake
Heat Exchanger
Bro, you should be running 12.2's not 13.2's. Get that thing on a dyno and get some info on your program. I am sure all of you will make it into the 12's. I ran a 13.01 in my quest(4lber, JDM chip, converter and pump gas). I was STUCK there. Swapped my fuel filter and the next time out I ran a 12.52! I was happy to say the least. Then a couple days later I blew a plug! YaY! -Mat-
Old Jul 3, 2004 | 08:38 PM
Johnny AC's Avatar
Track Time
Hey Matt, have you been to the track to try out your new motor, just curious.
