Cams?
Old Jul 2, 2004 | 05:56 PM
jakhammer's Avatar
Cams?
Ok, here is my cam question for the day. Do any of the cam grinds for a lightning have a lopey idle. I am guessing not, but I would like to know.
Also, are cams worth anything on a mild L like mine (see mods)?
Chris
Old Jul 2, 2004 | 07:01 PM
cpeapea's Avatar
what would make you think they wouldnt lope? mine sure as hell does
Old Jul 2, 2004 | 11:20 PM
jakhammer's Avatar
im rusty on cam physics, but isnt the lopey idle caused by valve overlap? if it is, it seems like all that overlap is overkill for a sc engine as having both valves open at the same time would waste fuel and air.
BUT, i am glad there is a lopey idle cam for a 5.4. that kicks ***. what kind do you have? anything else that needed to go with it i.e. ported heads?
Chris
Old Jul 3, 2004 | 12:02 AM
Bad as L's Avatar
hammer
the effects of the overlap change with rpm, what might be too much at idle is just right at shift point.
Old Jul 3, 2004 | 03:49 PM
jakhammer's Avatar
Holly crap, .581 lift, thats insane, but kewl as hell! I might have to check into cams now. I would love to have a noticable idle, with some reworked exhaust.
Chris
Old Jul 4, 2004 | 01:33 AM
01svtL's Avatar
Has anyone put cams in the stock block without ported heads or anything?
Old Jul 4, 2004 | 10:25 AM
LatemodelRacer2's Avatar
after i get my nx im gonna put stage 2 cams on my stock block well see how it goes
Old Jul 4, 2004 | 12:31 PM
01svtL's Avatar
Cool, let us know!
Old Jul 4, 2004 | 07:39 PM
cpeapea's Avatar
I had mine ported, so i cant really say, i think cams will yield more though
Old Jul 5, 2004 | 09:29 AM
TimBurntire's Avatar
We've used those cams in several of our built motors with good luck and they make good power. A nice little lope at idle and they take the power band up a couple of hundred rpm.
Old Jul 5, 2004 | 02:51 PM
blacksunshine01's Avatar
cpeacpea, What are your cam grinds? I know you have a built block, and porting, and your L sounds like a pissed off beast ready to attack at full throttle. You've seen my L and I think you know most of my bolt on mods, Im considering a cam spring swap and want a good grind for my set-up with a stock motor. Is your cam too radical for a stock block 4-6# pulleys, intake, long tube headers, etc..?
Old Jul 5, 2004 | 03:15 PM
01svtL's Avatar
It wouldn't hurt the motor at all to put in stage II cams with stock internals would it? I have long tubes and full exhaust, and want a little lope to it. Would I still hear the lope if everything else motor-wise was stock? I'm also running a 4# lower/2# upper. Would the chip have to be reburned or anything?
Old Jul 5, 2004 | 05:10 PM
cpeapea's Avatar
i went with modmax street and strip grinds. they are similar to th comp stage 2s i think
Old Jul 5, 2004 | 11:02 PM
cpeapea's Avatar
yes they were pricey, but they were the first mod motor cams out on the market at the time
Old Jul 6, 2004 | 02:30 PM
TheGoaT's Avatar
has anyone tried stage 3 cams on a streetable truck?
Also do you think doing cams on a 450hp truck with a stock block would push it over the edge?
