Traction problems
Old Jul 2, 2004 | 07:50 AM
tommylightning's Avatar
Traction problems
Well ever since I added the 3" upper to my KB I have had problems with traction. I have the 30" Hoosiers but thinking about going to the radials. Last night is not a good indication because no one was doing well in the traction department. My 60fts were 1.7Xs. Two passes were on a 100 shot and it went 11.1 @ 127mph and 11.2 @ 127mph. If I can just get this thing out of the hole like I used to (1.5s or better). Anyone have any suggestions?
Old Jul 2, 2004 | 01:46 PM
MISTERgadget's Avatar
Add more nitrous to make up for it.
Old Jul 2, 2004 | 01:56 PM
KIRST8404's Avatar
Are you spinning the tires? what's the problem?????
I know, let me drive!!!!!
Old Jul 2, 2004 | 02:18 PM
Haha Yes the tires are spinning, last night was very bad. I was easy on the gas and the tires were spinning at 1/2 throttle.
Old Jul 2, 2004 | 04:30 PM
blown318's Avatar
tommy you comming to Joliet???
Old Jul 2, 2004 | 04:45 PM
Dale-01L's Avatar
Are you spraying out of the hole?
The only luck Ive had with hooking up as been to launch the truck off-spray and start spraying at like 60' or 100' mark... Even on a well prepped track...
That has netted me my best 60' times (Low 1.5x's with a best of 1.51)
-Dale
Old Jul 2, 2004 | 05:02 PM
grinomyte's Avatar
how old are your shocks?
Old Jul 2, 2004 | 07:13 PM
No not going to Joliet but I will be at Atco.
Even runnig my ritrous file without nitrous I blow the tires off. I was very easy out of the hole and still spin the tires. I am past the 60ft before I spray it.
My rear shocks are QA1s and are about 10K miles old.
Old Jul 2, 2004 | 07:34 PM
jarmstro's Avatar
Tom, what are the settings on your QA1s? I run mine on 6.
Before you rebuild everthing keep in mind your comment track was not hooking well for everybody.
I ran into the same problem at our local track. During Fun Ford here in Houston I had 1.5X sixty foot times but 2 weeks later I had 2 1.8Xs sixty foot times and 1 1.9X. I was not happy, however I was not alone others on the track were having the same problem(s).
Your Linelock is kick a$$
Old Jul 3, 2004 | 01:05 AM
SVT F15O's Avatar
Maybe you should spend more time taking care of your customers! I am here and haven't been able to go to the track in what now, 7 months>??? Awesome! -Mat-
