drop and traction bars...
Old Jun 30, 2004 | 12:59 PM
samiam513's Avatar
allready seached... found nothing...
If i add 58" traction bars now, then do 2 inch drop shackles in a month, the traction bars will need to be adjusted on the front bracket. correct?
Old Jun 30, 2004 | 01:15 PM
D Davis's Avatar
Re: drop and traction bars...
Iwould also like opinions on this, as I did same with out changing front. Thought about it, but also did'nt see anything saying it should be
Old Jun 30, 2004 | 03:27 PM
Speedin Bob's Avatar
From: On the side of the Road attempting to explain 135 miles per hour
Yes, the brackets will more than likely need to be relocated. Eight more holes in the frame.
Drop first, traction bars second.
Old Jun 30, 2004 | 07:08 PM
LightninSVT's Avatar
I've got the FRPP kit that lowers it 30mm all the way around, and I have a set of LFP bars on the way. Are these going to fit in there perfectly or am I going to have to mess with *****?
Jon
Old Jun 30, 2004 | 08:40 PM
Jon,
Install the drop kit first, drive it for a couple of days, then bolt the LFP bars up and you'll be all set.
Bob
