to be able to make the 11.99 or lower pass
Old Jun 26, 2004 | 02:59 PM
thehammer's Avatar
Cool to be able to make the 11.99 or lower pass
Motor is finally back in the truck with a built bottom end , only took 6 weeks
Had the truck dyno’d with the 6lb pulley and pushed a 480 rwh/600tq
8lb pull to come this Monday, as we were having cpu problems.
I have the apten port job so the question is what is the best pulley for street use as this is a daily driver (mostly highway) the 6 or 8?.
i think it would be more impresive so I would like to be able to make the 11.99 or lower pass at the track without using the nos,
Can I do that with the 8lb or would I have to go to the 10lber.
Any other ideas would be helpful
mods:
LFP interchangeable lower pulley 4,6,8lb, boost bypass, apten port job, , revolution chip, kooks stainless long tube headers, JDM catback exhaust, duel electric fans, cobra r electric water pump, JLP intake, accufab 1696cfm single blade throttle body, 50lb injectors, NGK TR6 plugs, Metco idler relocate, Factory Tech valve body, b&m deep tranny pan, 3/5 lowering kit, JLP rancho's bars QA'1s rear shocks, bell tech front coil springs, KYB-- front gas shocks,JLP Large Capacity Heat Exchanger.
new editions--BUILT BOTTOM END,2600 stall torq convertor,Nitrous express (2 stage)50 ,,100 shot
last dyno--450rwh/580fttrq---12.79@106.4
Old Jun 26, 2004 | 03:45 PM
Hilander's Avatar
I have a similar setup to you, just minus the nitrous and no headers. I do have cams and ported heads.
To answer your question I run with a stock upper pulley and an 8 pound lower with the same Apten port.
Old Jun 26, 2004 | 03:53 PM
BuiltL's Avatar
My Question is how did you only run 12.79@106.4 with 450 hp and 580 torque. And is that 600torque run on the dyno with nitrous?
Zach
Old Jun 26, 2004 | 03:54 PM
thehammer's Avatar
whats your best time you have posted?
and have you been happy with that set up for the street
Old Jun 26, 2004 | 04:03 PM
thehammer's Avatar
Zach
not sure i did have some chip problems, It seems to me my 60ft times with slicks are hurting me a bit, best 60 ft time was a 1.83,
my times are at sea level with hiumidity at 65%
i hope that with the 2600 stall convertor i will bring the 60ft times down.
the 600torque run was without the nos,
the nos wont be setup till i get a few miles on the new motor.
Old Jun 26, 2004 | 05:07 PM
Rob_02Lightning's Avatar
Zach
My guess is he has a nice safe tune.
Old Jun 26, 2004 | 09:40 PM
thehammer's Avatar
rob is right, I had some problems so we kept the truck running rich with the 50lb injectors,
I had oringaly had the 95 ml mass and k&n filter, then I upgraded to the JLP intake which thru things off, then came the apten port job,
the right opportunity came to get the block built, so I haven't been back to the track.
Old Jun 26, 2004 | 09:41 PM
thehammer's Avatar
any thoughts on running with a 10lber????
Old Jun 26, 2004 | 11:52 PM
Hilander's Avatar
I am running a very rich tune right now 10.0 A/F. I love the truck on the street, it's a blast.
My best time so far on the street tune with an A/F of 10.0 is 12.5@111mph....but I am at 5500 feet altitude and the air correction on the night was over 7000 feet. So I would hope to get somewhere in the 11s in good air at sea level. I plan a trip to lower elevation later this year.
As far as the 10 pound pulley, I would imagine it will only produce a vast amount of heat. BTW with my 8 pound lower, Apten and ported heads and cams I see 14 pounds of boost. What do you get?
Old Jun 26, 2004 | 11:57 PM
theperfectstorm's Avatar
Well hammer, I have just about what you have.
With a 4# lower, and a 2.80 upper( 1&1/2#'s) or about 5&1/2#'s total, I have run a best of 12.27 in GOOD air!
A 8 # pulley would put you cloooose to a 11.99.
Old Jun 27, 2004 | 02:33 AM
thehammer's Avatar
thanks
i tried the upper pulley with the 6lb but was getting to much slippage,
[/QUOTE]
Thats what i'm looking for
Old Jun 27, 2004 | 02:41 AM
thehammer's Avatar
will be running two chips,
#6lber street without nos/ with 50 shot nos
#8lber track without nos/ with 50 shot nos off the line and 50 shot after 60 feet.
with the #6 for the street
my tuner ended up with 480/550tq
he back down the torq quite a bit for the strret.
A/F is at 11.8 at 15 pounds of boost
tunning the 8lb this week, this will be for the track
Old Jun 27, 2004 | 03:09 PM
thehammer's Avatar
what tires were you using?
Old Jun 27, 2004 | 05:23 PM
SVT F15O's Avatar
If you are making 480RWHP and 600RWTQ, you can run 11's all day long just so you know. If you get traction you will have it. Best of luck. -Mat-
Old Jun 27, 2004 | 05:35 PM
thehammer's Avatar
thanks
hey mat did you run that 11.37 with the eaton or kenny bell?
and what should be my 60 foots be at.
best without the convertor was a 1.83 with slicks.
hoping this new convertor will help.
