Going to the dyno tomorrow, a few questions!
Old Jun 25, 2004 | 08:51 PM
jster171's Avatar
Banned
As the title states, I'm heading to the dyno tomorrow for the first time in my life. I know that the truck needs to be in 3rd gear which means turning the OD OFF with the button. But question one, what RPM do I need to be at so it doesnt down shift to second and 3rd, what about the fuel curve under than specified RPM??
Old Jun 25, 2004 | 09:03 PM
ByByBird's Avatar
Your dyno guy should be able to handle those ?s for but if not then I will..
80mph in 3rd gear is 3,200 rpms. That should be a good spot to nail it with out it down shifting.
Sal has responded to the A/F ? before. At the track when your L shifts into 3rd gear @ WOT you will never go below 3,000 rpms thus not worring about it. The only time your below 3,000rpms is during the launch and you only there for a sec or so. Understand?
Old Jun 25, 2004 | 09:19 PM
jster171's Avatar
Banned
That makes perfect sense, but since I use my truck as a daily driver, I SOMETIMES never go above 3000 RPM in my journeys, so Id like to know that everything is fine in that area.
Old Jun 25, 2004 | 11:54 PM
ByByBird's Avatar
If your just worried about crusing conditions...DONT! You not making any boost @ crusing speeds and under part throttle you still making less boost then 8psi witch is well with in factory operating range.
The only time tuning become an issue @ part throttle is when you start to add on BIG items that effect HP/TQ constantly like Heads,Cams,Stoker kits, etc....
Those are very good ?s to ask if you know little about mods vs. tuning on any car/truck.
Old Jun 26, 2004 | 08:32 AM
superfords's Avatar
run the truck up to about 65mph and it won't downshift.
good luck. have fun.
later,
chris
Old Jun 26, 2004 | 09:16 AM
Certified Drunk's Avatar
If the truck down shifts, stop on the pull and start over.
Old Jun 26, 2004 | 09:50 AM
ByByBird's Avatar
later,
chris
Really? Mine down shifts @ 65???
Old Jun 26, 2004 | 09:57 AM
LightningTuner's Avatar
Bring it up to 3k in 3rd gear. That you should get you just about 70mph. Hit it from there.
Old Jun 26, 2004 | 10:10 AM
EZGZ's Avatar
Prolly not if you have the overdrive off
