Need Lug nut size for my E/T Streets
Old Jun 24, 2004 | 06:02 PM
georgia-SVT's Avatar
I bought some used M/T et Streets 26x11.5x16 on eagle alloy wheels I am assuming the 01 lug nuts will not work. What size do I need to get so I can test these things out this weekend. My best 60' on f1's was a 1.95 I'm sure I'll they will help me out.
jeff
Old Jun 24, 2004 | 06:46 PM
Johnny AC's Avatar
LUGZ
You'll need 14X2 mm acorn style nuts.
Old Jun 24, 2004 | 10:44 PM
O.K. 14x2mm what is the thread pitch 2.0?
jeff
Old Jun 25, 2004 | 06:54 AM
SVT_KY's Avatar
2 mm is the pitch
Old Jun 25, 2004 | 08:06 AM
SMOKINTRUCK#1's Avatar
I got the long acorns easier to get on and off. Don't for get the driveshaft loop!
Old Jun 25, 2004 | 08:26 AM
Am I going to need a drive shaft loop with ET Streets I got Stainless steel Tracksion bars to keep axle wrap from being a problem.
jeff
Old Jun 25, 2004 | 08:47 AM
jarmstro's Avatar
jeff
Take one of your stock lug nuts with you or your truck and remove one of the lugnuts so you can make sure you get correct ones.
The new acorns lugnuts should turn as smooth and as easy as the stock lugnuts.
Old Jun 25, 2004 | 12:10 PM
Will do but do I need a drive shaft loop for ET Streets?
jeff
Old Jun 25, 2004 | 12:31 PM
WideOpen03SVT's Avatar
I know you'll need a driveshaft loop because you'll run faster than 14.00. NHRA states that any vehicle running 13.99 or faster needs to have a driveshaft loop. But at my local track, they want you to have it whenever you run sticky tires. My brother has the JLP loop and it is really nice....has a black powdercoat. There are also the Metco loop and the one from Chassis Engineering.
