How much boost will a 2.7 pulley give me?
Old Jun 23, 2004 | 05:31 PM
Alvin433's Avatar
How much boost can i see wiht a 2.7 pulley and how much horsepwoer can I expect from it?
Just bought one, thanks
Old Jun 23, 2004 | 05:41 PM
easterisland's Avatar
I'm guessing about 30 psi.
Old Jun 23, 2004 | 06:15 PM
EZGZ's Avatar
Easterisland, your bad to the bone LOL
No soup for you, Next please!
Old Jun 23, 2004 | 06:59 PM
cpeapea's Avatar
inches not feet
Old Jun 23, 2004 | 07:02 PM
Dale-01L's Avatar
Assuming that small upper pulley wont slip (which it will)
A Stock Lower / 2.7" upper combo will spin the blower about the same speed as a 4# lower / stock upper combo will...
7.9 / 2.7 = 2.93:1 Ratio
8.5 / 2.93 = 2.90:1 Ratio
So, in a perfect world, you should get 3-4psi depending on weather/othermods/etc... But, that teensy little upper pulley will slip considerably more than just a 4# lower...
-Dale
Old Jun 23, 2004 | 07:23 PM
Alvin433's Avatar
3-4 pounds really??
Awesome
BTW>. this ain't on a lightning.. its making 9psi now.
Old Jun 23, 2004 | 07:24 PM
Alvin433's Avatar
what do you guys usually pick up with the eaton and 3-4 more pounds..
You really can't compare it to anything out there for us.. vortch etc..
Old Jun 23, 2004 | 07:38 PM
Unoid's Avatar
well since its not a lightning the results may vary depending on MAF/ upper intake/phlenum(sp?) and the effectivnes of your intercooler to cool the hotter air charger s from your heaton.
but a fairly good guess would be with 4 lbs + = 30hp and 40torque?
Old Jun 23, 2004 | 09:17 PM
ByByBird's Avatar
Originally posted by Alvin433
3-4 pounds really??
Awesome
Nope it's on a fbody!..I reconize you from CZ28..I switched to the dark side and bought a L
