Trouble removing stock lower pulley
Old Jun 19, 2004 | 01:25 PM
JimJr's Avatar
Title says it all.
Took the inspection plate off and locked that up. Broke the pulley loose with a breaker bar and thought everything was going good. The pulley was getting really loose and then all of a sudden it started getting tighter until the point i couldnt even turn it anymore. WTF. Tried going the other way. Once again it broke free and then did the same exact thing. Spent 3 hours on it and got no where. Anyone have any pointers? BTW When i was on the creeper below the truck i was turning it clockwise. Do they mean clockwise from under the truck or outside looking at the truck? Thanks for the help. Anyone wanna stop by MASS and give me a hand?
Old Jun 19, 2004 | 01:30 PM
LightningTuner's Avatar
Here you go...
http://members.aol.com/powersurgeper...eyinstall.html
Keep in mind that this install shows a 99-00 style. The 01-up ios the same thing, it just doesn't have the adapter (it's part of the balancer on 01-up). I made this install page back in 99 when I designed the cageless Lightning pulley, so it's kind of old .
Old Jun 19, 2004 | 01:55 PM
Odin's Wrath's Avatar
Re: Trouble removing stock lower pulley
Originally posted by JimJr
Title says it all.
Did you remove the 3 bolts from the cage before you started backing the pulley out?
Old Jun 19, 2004 | 01:57 PM
Txoutlaw's Avatar
Edit: Removed my three bolts for cage comment. Odin beat me to it.
Outside the truck it's clockwise....under the truck it's couter-clockwise. While laying under the truck, you should be pushing/pulling the breaker bar from driver side to passenger side. Hope you get it removed. Good luck!
Old Jun 19, 2004 | 05:16 PM
Rob_02Lightning's Avatar
Jim it does sound like maybe you didn't have the three bolts off ??? I truly see no reason the Factory threads should be
screwed up. Plus I've never heard of anyone having a Prob
taken the stock caged unit off ???
I hope you worked it out
Old Jun 19, 2004 | 05:52 PM
JimJr's Avatar
i think you guys might have it..........what are the 3 bolts? is it the kinda anodized piece of metal behind the pulley? if so i never touched these. is that the reason why? anyone have a picture of what your talking about? thanks
Old Jun 19, 2004 | 05:59 PM
Did you go to the link I posted above??
Old Jun 19, 2004 | 06:01 PM
Stl01SVT's Avatar
The lower pulley is attatched to a cage, that is bolted to the engine by three bolts. These bolts have to be removed, to remove the pulley/cage assembly.
Old Jun 19, 2004 | 06:10 PM
JimJr's Avatar
yes i did........i can kinda see the part your referring to and no i did not unbolt it. Took the directions off RPMOutlet.com and it only said to move one bolt from there. thanks i think you got it.
Old Jun 19, 2004 | 06:11 PM
It looks like the assembly behind the aftermarket pulley in this picture.
Open the link Sal provided and go through the installation step by step. You'll see where you messed up.
Old Jun 19, 2004 | 06:45 PM
1
2
3
Old Jun 19, 2004 | 06:47 PM
4
5
6
Old Jun 19, 2004 | 06:48 PM
7 (ALL DONE)
DONT FORGET TO REMOVE Torque Convertor Lock Down
Thanks for the Pic's Sal / PSP ..............
Old Jun 19, 2004 | 07:21 PM
Originally posted by Rob_02Lightning
7 (ALL DONE)
I'd like to stress the point...
DO NOT FORGET TO REMOVE
THE ENGINE LOCK UP TOOL
BEFORE STARTING YOUR TRUCK!
Old Jun 20, 2004 | 12:23 AM
JimJr's Avatar
it was the part i forgot to remove............i'm gonna give it hell tomorow! haha thanks Guys.
