Making the engine bay hoses Black again???
Old Jun 18, 2004 | 09:20 AM
  #31
RED 92's Avatar
some things you can do if your showing your truck that are subtle are sticking a breather at the oil cap location when you get to the show.....
and if you have time polish your differential
and hope Vinnie's truck is not at the show......
Old Jun 18, 2004 | 02:53 PM
  #32
brain bypass's Avatar
Originally posted by EZGZ
Just used simple green on mine this weekend. It turned the hoses white.
I use "303" and wiped down for that brand new look
ditto
the 303 gives them a moist but no greasy look. like it is brand new
Originally posted by fractaldragon
Thanks! BTW, the 03+ trucks have the new coolant in the IC. Pre-03's use the green stuff. What year is yours?
uhh, negative ghostrider.
mine is an 03 with the normal green coolant.
and RED 92, i like hoe you painted the logos on the front of you SC. looks nice, but subtle
Old Jun 18, 2004 | 04:47 PM
  #33
BMWBig6's Avatar
Has it ever been flushed/refilled by the dealer? All of the 03's I have seen (including mine) came from the factory w/ the gold stuff. Maybe they switched mid-model year?
TSB:
Article No.
02-23-7 COOLING SYSTEM - MOTORCRAFT PREMIUM GOLD ENGINE COOLANT - SERVICE TIPS
Publication Date: November 19, 2002
FORD: 2002-2003 ESCORT ZX2, FOCUS, MUSTANG, SABLE, TAURUS, THUNDERBIRD
2003 CROWN VICTORIA, GRAND MARQUIS
2002 EXCURSION
2002-2003 E SERIES, ESCAPE, EXPLORER SPORT TRAC, EXPLORER SPORT, EXPLORER, F-150, MOUNTAINEER, RANGER, SUPER DUTY F SERIES, SUPER DUTY F-53 STRIPPED CHAS.
2003 EXPEDITION, WINDSTAR
2002-2003 F-650, F-750
LINCOLN: 2002 CONTINENTAL
2002-2003 LS
2003 TOWN CAR
2002-2003 BLACKWOOD
2003 AVIATOR, NAVIGATOR
Article 02-17-7 is being republished in its entirety to update the text and part numbers.
ISSUE:
A new, extended-life engine coolant, yellow-colored Motorcraft Premium Gold Engine Coolant, meeting Ford Specification WSS-M97B51-A1, service part numbers VC-7-A and VC-7-C (for use in the U.S., except California and Oregon) and VC-7-B (for use only in California and Oregon as it contains a bittering agent), has been equipped in all of the vehicles noted above. The initial-fill life for this coolant is 100,000 miles/5 years. Due to variations in water quality, the replacement interval is 50,000 miles/3 years.
ACTION:
Any time the addition of coolant or a coolant change-out is required, USE ONLY THE TYPE OF ENGINE COOLANT WITH WHICH THE VEHICLE WAS ORIGINALLY EQUIPPED. DO NOT MIX COOLANT TYPES. To determine the type of coolant required, check the color of coolant in the coolant reservoir of the vehicle or refer to the applicable vehicle's Owner's Guide or Workshop Manual for service parts and specification information.
SERVICE INFORMATION
Except for heavy-duty vehicles equipped with the Caterpillar 3126E engine, the use of a supplemental coolant additive (SCA) such as Motorcraft Heavy- Duty Cooling System Additive, service part number FW-16, is not required in conjunction with this coolant.
Testing is currently underway to determine the backward compatibility of the Motorcraft Premium Gold Engine Coolant in vehicles equipped with the green-colored Motorcraft Premium Engine Coolant, service part numbers VC-4-A, VC-4-B, and VC-5. Until the final test results are available, vehicles should ONLY be serviced with type of coolant with which they were originally equipped.
Please note that Motorcraft Premium Gold Engine Coolant is not compatible with any orange-colored, extended-life engine coolants such as Motorcraft Specialty Orange Engine Coolant, service part numbers VC-2 and VC-3. DO NOT MIX COOLANT TYPES. USE ONLY THE TYPE OF COOLANT WITH WHICH THE VEHICLE WAS EQUIPPED. Failure to follow these guidelines may result in degradation of corrosion protection and potential engine damage.
