Blower Bolt Pattern and TQ Specs Needed
Old Jun 15, 2004 | 09:11 AM
Crued's Avatar
Can someone please post the order and torque specs for the supercharger AND upper pleanum bolts.
Old Jun 15, 2004 | 09:26 AM
tallimeca's Avatar
hmmm
do a search, chris posted it for us back a month or so ago when i asked. It's basically a cross pattern. 1st torque to 18ftlbs, then second stage to 36 I believe. Double check first. Do a search under torque specs or blower torque specs and theres a TON of info.
Old Jun 15, 2004 | 09:32 AM
Rob_02Lightning's Avatar
EVERYTHING you need is right here
https://www.f150online.com/forums/sh...t=supercharger
Great Post, FROM A GREAT GUY
Old Jun 15, 2004 | 10:42 AM
Crued's Avatar
thanks a bunch, i tried searching, but only came up with misc posts about blowers and dyno numbers.
Old Jun 15, 2004 | 01:01 PM
Tim Skelton's Avatar
You Search ***** should be ashamed of yourselves.
Old Jun 16, 2004 | 01:45 AM
teamsvt2002's Avatar
Re: Blower Bolt Pattern and TQ Specs Needed
What torqur specs and bolt order?
I just bolt it however and forgot it. No torque specs no nothing. So far nothing has gotten lose or falllen off.
And today I beat a C5 vett from dead stop to 120 mph by 2 L's (gota lov them drag Nittos on the street)
I also raced a RX somthing sportbike from 65 mph to 125 mph and I was just slightly ahead of him. (wussie he was afriad to keep going)
See no harm done without using torqur specs and bolt order..... so i hope
Old Jun 16, 2004 | 09:01 AM
Crued's Avatar
I have a ported blower that I bought from a forum member that is making a TON of noise after 5 miles of use. He claims the issue has been previously seen to possibly be proper torquing of the bolts. I've installed blowers before also without patterns and torque wrenches. But, to avoid being screwed out of $$$ I will try anything.
