Header?
Old Jun 11, 2004 | 10:19 PM
TriPodRacing's Avatar
Header?
Ok I have the driver side in. I take it that I have to lengthin the wires on the O2 sensors.
Also any tips on the Pass. side install..
Thanks Joe
They are JDM/Kooks headers if you need to know.I bought used so no dir.
Old Jun 11, 2004 | 10:24 PM
Don's Bolt's Avatar
Call JDM they can get you 02 extensions
Do Not Cut The Wires
Old Jun 12, 2004 | 12:04 AM
SlowSVT95's Avatar
Re: Header?
Yeah, good-friggin-luck.
Old Jun 12, 2004 | 04:28 AM
Bad as L's Avatar
It will slide in from the passenger side wheel well, it should fall in almost as easy as the drivers side but then again I've done it about 20 times or so it seems
Old Jun 12, 2004 | 09:34 AM
Certified Drunk's Avatar
You might need to remove the wires from the starter.
Old Jun 12, 2004 | 02:36 PM
Thanks guys...One more ? did any of you have a problem with the starter wires touching the header?
