whistling or sucking sound
Old Jun 9, 2004 | 04:05 PM
mhays26's Avatar
I just put a 4# lower pulley and 67" Gatorback belt on. I have a whistling sound, sounds like a air sucking sound when on the throttle at low rpms. I had to break the tensioner clip to get this belt on, and I was wondering if I could have this sound because the belt is too tight. Ive read that normal belt for 4# is 67.5 or 68. Is this something to be concerned about and should i try the bigger belt? Also, James at RWTD said it may have something to do with boost bypass, since when I take the blower belt off it doesnt make the sound anymore. He said to check the valve and make sure it is seated correctly, and I dont know where to check at. Could someone shed some light on this too, maybe.
Sorry to be so long, and thanks for the help in advance,
Matt
Old Jun 9, 2004 | 04:42 PM
TheYak's Avatar
I am also running a 4#er and a gatorbelt, same noise. I think it has more to do with the belt tread than anything else. I sprayed Prestone belt dressing and it made it louder! Oh, well.. i kinda like it now. I don't think that you have anything to worry about.
TiresWinRaces's Avatar
I think you're talking about the normal Gatorback belt whine. I believe the consensus is that it's from the cross ribbed belt. Sounds like a turbine, or a little like a centrifugal blower at low rpms. Mine does it and I love the sound when cruising through the hood.
Nothing to be concerned about I would say. I used a 68.0 on mine, but alot run 67.5. You should be OK though.
Old Jun 9, 2004 | 04:57 PM
DUCK01's Avatar
Oh - I thought you said "whistling AND sucking." I was just gonna say that you probably heard me whilsting Dixie while the fiance earned another ride in the L.
Who am I kidding - I sold the L...
