Rim size for 26x11.5x16 Et's
BTW Easter, an ET street is a slick, it is the same compound as ET drags in most cases, the only difference is a couple of groves...But you knew that, PAL!
Thanks Slick for backing me up.
A: No! Even if you cut your own grooves they are not street legal.
ET Street tires have passed D.O.T. requirements but have reduced tread depth and compounds designed for racing. Due to the reduced tread depth these tires should be used on dry pavement only and are not suitable for normal highway use!
DOH!
Looks to me like E.T. streets are legal( have passed D.O.T. requirements). The E.T. Drag is not under any circumstances street legal.
That's nice, but it doesn't mean that the two tires are not the same other than the grooves. That only means that one has been approved by the DOT for street use. All they are saying is that you cannot groove your EG Drags to make them legal as they do not have DOT numbers stamped on them.
The tires are made the same and are the same compound, the only difference in construction are the grooves, PAL!!!
Apparently you like to argue, but you have chose the guy to do it with PAL!!
I feel like I am having a battle of wits with an un-armed man!! LOL
Originally posted by SLICK0478
I run my ET streets on a 8" rim and there fine but I don't trap at 120 more like 108-110 anyone who's running that fast would probably be running a 30" tire ( I am not saying you trapped at 120) But who would run et streets up 120 on the street for fun just stupid ( my opinion)
Too bad you didn't get 28" hoosiers they are a better tire and your rpm will be down a bit at the end of the 1/4 compared to 26"'s
Also Fomoco is right mt et does reccommend 8" rim or thats what there web site chart says
Slick
Slick
I won't dispute the fact that MT recommends a 8" wheel for a tire which wasn't even asked about.
...an ET street is a slick, it is the same compound as ET drags in most cases, the only difference is a couple of groves...
Ah, But you did dispute it, infact you called M/T stupid! I suppose you were wrong again, correct??
For the intellectually challenged, I stated above that the only difference in construction were the grooves. They are "slicks" with grooves...So to answer your question, this post is about "slicks", ok PAL??
Ah, But you did dispute it, infact you called stupid! I suppose you were wrong again, correct??
You did dispute M/T's recommendation of 8" rims for 28/11.5/16 and called it stupid to do so! Now you are saying that you don't dispute this fact....which way is it??
I did not mean that you phoned M/T, you called it stupid to use 8" wheels for 28/11.5/16 tires
Second, I don't dispute that M.T. lists 8" wheels for their 28/11.5/16 et street. I never have at any time.
Originally posted by easterisland
Besides, running 28/11.5/16 et streets on 16x8 wheels is stupid. The wheels are too narrow. Traction is compromised along with safety. With 20psi 16x8 wheels with 28x11.5x16 et streets on a 5700lb truck are extremely unstable at high speeds.
Excuse me, but is this your post??
It would appear that you are disputing M/T's recommendation of 8" wheels for 28/11.5/16 tires, PAL!!!
or are you just suggesting that you know better than them what is best??
Like I said, I don't dispute that M.T. lists the specs of their 28/11.5/16 et street on an 8" wheel on their website. I have no idea if that is the recommended wheel for the application. You would have to call and ask them.
I personally wouldn't use a 16x8 wheel with that tire. Apparently, you would use nothing other than a 16x8. Do whatever you want it is your truck.
Let me help you then...
From the M/T website:
Acceptable practice for rim width is tread width plus or minus 1 inch. All dimensions @ 10 psi cold on measuring rim.
This would mean that with a 8.7" tread width the 28/11.5/16 "slick" would not be acceptable for 10" rims!!!
As far as the "slicks" issue checkout this Jegs ad:
http://www.jegs.com/cgi-bin/ncommerc...39&prmenbr=361
Notice the line "Street legal racing slicks"
No, not at all...
I just get alittle miffed when some jag-off who obviously doesn't know what he is talking about calls my advice and/or M/T's recommendations STUPID...based on his POS truck being unstable....personally I think the driver was unstable...LOL
No, not at all...
No, not at all...
Easterbunny has a way with people
