Rotors and Bearings
Old Jun 8, 2004 | 01:59 AM
95 Saleen S351's Avatar
Rotors and Bearings
When pulling the rotors off to get them machined, is it required to pull the rear greace seal and the rear bearing?
Old Jun 8, 2004 | 07:25 AM
Fear Itself's Avatar
Pull the seals and bearings, clean all the grease out, and leave the races in.
David
Old Jun 8, 2004 | 11:22 PM
Any trick to getting the rear seal off and bearing out?
Old Jun 9, 2004 | 07:41 AM
Don's Bolt's Avatar
after you take the grease cap off remove the front bearing put the nut back on and pull the rotor out ward. The rear bearing should help release the rear seal.
