50lb injectors?
Old Jun 4, 2004 | 08:12 PM
TriPodRacing's Avatar
50lb injectors?
I,m looking for 50lb injectors.
Best price?
Any websites to check?
Old Jun 4, 2004 | 08:16 PM
LightningTuner's Avatar
I don't care much for the 50s, so we never sold them. I used to sell the 55s, but now we sell the 60s, since they are only $20 a set more and give a higher hp range. We have them in stock, $520 a set. They aren't listed on our site right now, but you can e-mail or phone in an order. Hope this helps.
Old Jun 4, 2004 | 09:08 PM
Don's Bolt's Avatar
I have a little differnt point of view on the 50's and 55's since I have had both in my truck. First I had the 50's and then swapped them out for the 55's. I hated the 55's so I returned them and went back to the 50's. I have never tried the 60's so I can't comment on them.
I can tell you the 50's idle and drive better than the 55's, and I run a 11.7-12.0 air fuel with the 50's.
Old Jun 7, 2004 | 10:21 PM
Thanks for the replies!
Any suggestions on best price for 50lb flow matched injectors?
Old Jun 8, 2004 | 12:53 AM
venomous's Avatar
find/do a search for Casey02L and ask him. He has a set on his he could probably point you in the right direction
Old Jun 8, 2004 | 01:58 AM
Casey02L's Avatar
Yup; I got 50's in my truck right now. They are working great. Any injector should work fine so long as the tune is setup right for them. The only problem I have with the truck right now is a cold startup issue, but that is a problem I have to fix in the tune; not the injectors fault.
People have always said it, and I totally agree. "It's all in the tune"
Old Jun 8, 2004 | 06:56 AM
Casey02L...Where did you get your injectors from and are they flow matched?
Thanks Joe
Old Jun 8, 2004 | 10:12 AM
Casey02L's Avatar
The only place I could find that had any in stock was JDM, and yes they are supposed to be flow matched.
