lowering questions
Old Jun 1, 2004 | 05:52 PM
BLUE N BLOWN's Avatar
lowering questions
im looking to drop the front of my truck about 1 1/2 to 2 inches. i have 2 inch shackles in the rear. what springs should i go with?? i hear alot about ruslow springs but what spring rate would i order to acheive a 1 1/2 to 2 inch front drop??? is anyone out there running a front drop spring with the stock bilsteins???i kinda wanted to see if i could get away with not changing them. how much will dropping the truck effect my track times?? and does anyone know a place in jersey that will swap the springs thanks alot
Old Jun 1, 2004 | 06:06 PM
rkoenig's Avatar
Re: lowering questions
Don't know which spring rate you should go with to get the drop you want. There are plenty of vendors who have springs which will drop the front of your truck the amount you want. I've heard a few people use the stock shocks with lowering springs, but I think it depends on how low the springs are. If they are only 1" drop springs, you should be able to get away with the stock shocks. Anything more than that, it may be a good idea to buy some aftermarket shocks, for example QA1's. Dropping the truck won't affect your track times all that much, either good or bad.
Old Jun 1, 2004 | 10:02 PM
LightninMike's Avatar
just get a set of lower control arms from djmsuspension
this will drop the truck 2 inches
