Nitrous switches...
Old May 30, 2004 | 09:48 PM
Duende's Avatar
Nitrous switches...
Hey all,
I'm getting a Zex kit here soon, and need some ideas on where to mount my switches for it at. So I'd like to see what all of you nitrous-guys have done...
Thanks for any pics/input. Appreciate it.
Thomas
Old May 30, 2004 | 10:09 PM
racetested's Avatar
Do you have any dummy covers that you can remove and add a rocker switch? You can use lighted to a solid black non-lighted for a nice clean factory look.
Old May 30, 2004 | 11:57 PM
MISTERgadget's Avatar
The flash wiped it out but the switches are LED tipped and turn on green when armed.
Old May 30, 2004 | 11:59 PM
Unfortuntely there are no dummy covers/knock-out panels that can be used in lightnings. Using the panel Rob_02_lightning did is the easiest way.
Old May 31, 2004 | 04:18 AM
Duende's Avatar
Sorry, was gone for most of the day watching a 'drifting session,' otherwise I would have thanked you guys sooner for your help.
Looks like a good spot. Thanks again, Mat.
Old May 31, 2004 | 10:59 PM
dogleg's Avatar
Hey Guys,
I used my map pocket. I cut a piece of alum., welded a threaded rod on the inside and put a wing nut on it to hold in in place after drilling a hole in the back of the plastic.
One switch to turn it on
One to open bottle
One to turn heater on
And a purge button
All this, and yellow to boot.
Alvin
