engine problems at high speed 01 L
Old May 29, 2004 | 06:03 AM
#18 of 6381's Avatar
My 01 L feels like it is going to shake apart at speeds over 100mph.
I did have the alignment prob. and had the cam bolts installed.
The truck did this before it launched a lug as well as after the fix.
it runs smooth all the way up to 100 then it feels like its going to come apart.
Any ideas?
Old May 29, 2004 | 06:04 AM
I meant to say launched a plug not a lug.
Old May 29, 2004 | 08:21 AM
Jkstang78's Avatar
Ok it sounds like you have a wheel balance problem. I would check all your wheels first to make sure that the wheel weights are still on them. Usually what your describing is a balance problem. It could also be a Driveshaft problem to. They have a weight on them also, and can loss them to. I am not to sure with the driveshaft on these Trucks though. Just trying to give ideas of what it could be.
