Cracked rotors
Old May 29, 2004 | 02:01 AM
johnathanh's Avatar
Unhappy Cracked rotors
Hi guys
I was washing my truck yesterday and found out that my rotors are cracked
There are little cracks on the front rotors
Do i need to replace them???
Don't know what to do. i've spend all my money on a built transmission
I was going to replace my stock pads with ceramix and now i am a bit of confused
Can i use the ceramix on the cracked rotors??
Is this safe??
thanks
Johnathan
Old May 29, 2004 | 04:05 PM
johnathanh's Avatar
ttt
Old May 29, 2004 | 04:15 PM
litnfast's Avatar
I just purchased these for $175 for the pair from Rotorpros in California.
Old May 29, 2004 | 04:24 PM
SVT_KY's Avatar
Call Stan Martin ... He has the best prices onthe best rotors
for our trucks ... dimpled and slotted ....
Old May 29, 2004 | 04:57 PM
Suavy's Avatar
those look sweet! I just paid 80 bucks a piece for rotor from car quest! I would have rather had those do you have a number or a link to them.
Thanks,
Suavy
Old May 29, 2004 | 05:00 PM
SICKBOY's Avatar
RUSLOW
is the way to go..I plan on gettin some here shortly
Old May 29, 2004 | 06:01 PM
litnfast's Avatar
Suavy...
http://www.rotorpros.com/index.htm
Old May 29, 2004 | 06:30 PM
Suavy's Avatar
thanks!
Suavy
Old May 30, 2004 | 12:20 AM
johnathanh's Avatar
Thanks guys
Anyone have more sites to order these drilled and slotted rotors??
I have to save some money now because i've just spend all my money on a built transmission
Johnathan
Old May 30, 2004 | 09:24 AM
SNCBOOM's Avatar
RUSLOW Rotors
There were previously mentioned which I also like.
Old May 30, 2004 | 11:58 AM
EZGZ's Avatar
Rotopros
There add speaks of zinc plating and no rust.
I suppose they are referring to the none braking surfaces as the pads would wipe out the contact area. Right?
Sure do like the looks of the drilled set.
What do you think caused the rotors to crack? What is your driving style. Sounds like severe service???
Old May 30, 2004 | 12:42 PM
Ruslow's Avatar
Drilling them will crack them.Look at the race brembos they are slotted only.That is the majority of them untill you get into the one cast for the drilling.Stan
Old Jun 1, 2004 | 09:22 AM
99 SVT Bolt's Avatar
A friend of mine had cross drilled rotors...guess what...they cracked. Slotted/dimpled is the way to go.
Old Jun 1, 2004 | 11:00 AM
Tim Skelton's Avatar
This is important and needs to be expanded upon.
There are two types of Brembo rotors out there. The first are the OEM-type replacement rotors (maybe @$80-150). AFAIK, they are NOT designed to be cross-drilled (meaning that the casting does not accomodate later drilling).
Then there are the Brembo "big brake kit" rotors (@$300). When these rotors are cast, the provisions for cross-dilling are made to the molds.
When a regular rotor is cross-drilled, there is a good chance that it will begin to crack around the holes -- especially with the kind of abuse that a 5,000 lb truck hands them. Even the specially cast rotors stand a decent chance of cracking.
I just paid $600 for some replacement Brembo rotor$. Like the originals, these are cross-drilled. The first set held up fine, wearing to minimum thickness without any cracking whatsoever. We'll see about these.
Old Jun 1, 2004 | 02:16 PM
SVT_KY's Avatar
The people at Brembo said "If you race at all, you
need the slotted version, NOT the drilled one. We
souldn't have even sold you the drilled ones if we
realized you would be racing it"
So after burning up the drilled Brembos, I now have
the slotted ones ...
Same price though .... < grin >
The only place to get slotted DIMPLED replacement
rotors for the stock setup in Stan ... ( cause he machines
them himself!!! )
