Drop Shackles
Old May 27, 2004 | 02:44 PM
whitebolt01's Avatar
Drop Shackles
Hey guys,
I was wondering what drop shackles work the best on the 03/04 Lightnings. I really want to just lower the back to level it out.
Thanks,
Simon
Old May 27, 2004 | 03:00 PM
PBGas's Avatar
If you check around, you'll note that most recommend the 3" shackle that a few vendors have. This would be due to the increased spring rate in the back with them bringing the payload of the truck up.
Myself, I am going to go with a 2" shackle. I only want to remove a bit from the back and don't mind a slight rake. I am trying to find a set though with grease fittings and urethane bushings....haven't found them yet.
Paul G.
Old May 27, 2004 | 03:07 PM
wydopnthrtl's Avatar
PBGas,
I just greased mine before installing. There is not really any need for a fitting. They don't get noisey like a mustang does.
Rich
Old May 27, 2004 | 03:59 PM
PBGas's Avatar
Thx Rich.
Will do. I figure I'll grab the Bell tech ones.
Paul G.
Old May 27, 2004 | 04:42 PM
rkoenig's Avatar
The Belltech shackles are pretty good. Not much difference I can see in any other brand though. Its just a piece of metal with a bushing at one end..
Old May 27, 2004 | 04:57 PM
Grimace's Avatar
Relocate your swaybar if you drop the rear. Or buy the 90 dollar set of adjustable end-links.
Old May 27, 2004 | 06:27 PM
RGCBSHRTY#1's Avatar
Which vender has the end links? I can't locate them.
Old May 27, 2004 | 06:45 PM
Grimace's Avatar
scroll down to about the 4th item
They are only 78 bucks but there is shipping to consider.
Old May 27, 2004 | 07:50 PM
I like the JLP shackles but the Belltech are really nice also. So I need to relocate my swaybar, if I drop the rearend?
Thanks,
Simon
Old May 27, 2004 | 07:55 PM
You don't have to spend money!!??
Just cut 2" out of the middle of your stock end links. Grind a healthy chamfer on both pieces and have someone weld them back together. It's simple, effective, and will noticably stiffen things up.
Did on mine anyway.... Rich
Old May 28, 2004 | 11:01 AM
Grimace's Avatar
Yes whitebolt you need to reloacate the swaybar when you drop the truck. All I did was level the swaybar and drill new holes in the frame to mount the links.
Old May 28, 2004 | 11:21 AM
Tim Skelton's Avatar
Old May 28, 2004 | 01:58 PM
FRANKS RED 03's Avatar
Ive got an 03 which sits higher in the rear and I installed 2'' shackles for djm,I got about 2'',Then I bought some 2001 rear leafs from a guy I know and put them on.I now sit 1/2'' higher in the rear which is about a 21/2''-3'' drop and never touched my sway bars and havent had a problem yet.Nor did I have any vibration problems eigther.Make sure you grease up the new shackles though,I forgot and had a terrible noise till I realized the dumb -azz mistake I made.I greased um up and have enjoyed them ever since
