Do I need a reburn for a torque Converter?
My chip is flashed for a slight increase in line pressure and torque reduction off do I need to get a reburn if I add a PI torque converter with a stall of 2400?
Would I be better off getting a 2400 stall or a 2600 stall converter for daily driver?
Thanks for your help.
Don't get me wrong I just don't want something I can't have on the street without causing any major problems with driveablity.
I am getting the PI just want to know what people have and their experances with there stall on the street.
i have the pi in my truck, i had the tranny rebuilt, and shortly after the convertor made noise so i went to a pi, and i drive it daily and in the winter, it has never given me problems, and very tame, i really cant even tell its there..
jim
jim
My 2500 stall converter is just fine for the street. It just gives that added launch ability when needed. + accidently burning the tires all of the time!
Thanks everyone for your insights.
Back to my first question.... do I need my chip reburn for the converter or not?
Still can't decide on which one the 2400 stall or 2600 stall.. I guess I will just flip a coin or something...
You don't need a reburn, but one might help, the stall is not a constant number, it;s more accurately expressed as a range, I suggest 2400-2600 which is prolly what you're looking at. The most accurate way to describe a converter is using K factor, but you just about need a degree in fluid mechanics to understand it. The 2400 is more than likely a 140 K factor impeller, the 2600 is prolly a 155K, for my 24-26 converter we use a 155K 11 1/4 diameter impeller with a 12 inch coverplate. The stock K factor is 110K, a GEN 1 stock is 135K and a Navi Converter is 140K to give you an idea of where you're at. Decreasing the diameter of the impeller and turbine lets me get the higher K factor and stall speed without losing the effeciency you normally do with a higher stall converter, by doing it that way I can leave the reactor completely closed and that helps make it a little more streetable, but with anything under 2800 stall you don't have much problem with that.
That said, I don't think you're spending the money very well for a street truck, the advantages you get from a stall converter aren't really that much on street tires. I sell them, and recently I've really had a lot of fun and interest in designing/building them, but I wouldn't recommend them to most people.
Just my 40% of a nickel
G
G
