What Would Cause Front-End to "Shimmy?"
was able to lower truck down another 0.5" few weeks ago, but now at speeds between 20-30mph, and 60-70ish mph, i get a front end shake, shimmy, etc. (steering wheel moving left / right very quickly)
Just pulled a wheel now, and got two long braker bars out to go over everything once again.
Top two (21mm?) bolts on control arm took a few small moves to get it "real phuckin tight."
anything else i may have overlooked?
list some causes (hope a wheel isnt out of balance!
Ummmm yer basic shakes:
Alignment
Brakes and rotor hot spots
Tire wear (uneven)
Tire Balancing
Bearings
Upper Control Arm bushings
Take the simplest cheapest and work your way up the list ....
They're all good things to check
Alignment
Tire wear (uneven)
Tire Balancing
Bearings
Alignment
Tire wear (uneven)
Tire Balancing
Bearings
Alignment
Tire wear (uneven)
Tire Balancing
Bearings
Have you checked the angle of the drive shaft? I've heard of some vehicles being lowered to much that the driveline is at such an angle to cause a vibration. This can usually be corrected by shims if that's the problem. Good luck.
Jack up the front end and give the wheel a good spin and stare at outside diameter to watch for high spots which could indicate tire seperation.
That would be all the time though.
Tire pressure the same?
In a few weeks wear you could have gotten some odd tire wear.
How about swapping with the back tires and see if it acts the same...
Mine shimmey's real bad every time I drive up this road.
http://www.mccullagh.org/image/d30-3...ad-tracks.html
Hah, the first thing that popped in my head with this posts title was the scene from AIRPLANE.
"She's begining to shimmy" and "She's begining to shake" with the big bewbs flying around.
lol.
lol.
