slicks and no traction bars?
Old May 12, 2004 | 03:44 PM
ST.ELMO'SFIRE's Avatar
hers what i got, 1/8 mile run, can i do it with slicks and no traction bars?
Old May 12, 2004 | 03:46 PM
brain bypass's Avatar
do tracks even allow that? i wouldn't even think about it.
Old May 12, 2004 | 03:47 PM
MaxPower's Avatar
Yes. They typically don't allow slicks without a drive shaft loop though - cuz that's what you're risking breaking - ESPECIALLY with that high stall converter.
Old May 12, 2004 | 04:01 PM
93Cobra's Avatar
I run ET Streets without either traction bars or driveshaft loop at the local track. I have to get a loop soon though, but I do not think traction bars will help me with my 60'.... or am I completely wrong about that? Currently pulling a 1.83 60' with a 12.66 @ 109.
Old May 12, 2004 | 04:26 PM
DEIMATT's Avatar
You can do it, you can have all the axle wrap you want and fix it when your done!!!
Man I wouldnt do it, get some truk traks or something, maybe one time if your dying to try it or something..
but order the bars today!!
Old May 12, 2004 | 04:48 PM
Lightning Bob's Avatar
Don't Try it with an aluminum driveshaft....
http://www.nloc.info/forum/showthrea...threadid=69709
You may be able to get away with it with the 99-00 steel shaft, but I would recommend buying traction bars.
Lightning Bob
Old May 12, 2004 | 05:24 PM
moses Black 01''s Avatar
Dont Try it. Your risking seriously screwing something up with all of the axle wrap your going to have
Old May 12, 2004 | 07:30 PM
cpeapea's Avatar
axle wrap will cause your driveshaft to break, when it goes and you DONT have a loop, then there is a big possibility of it either doing serious damage or flipping the truck upside down. ive seen it happen
Old May 12, 2004 | 08:03 PM
LightningToGo's Avatar
BE SAFE, GET TRACTION BARS & DRIVE SHAFT LOOP!
Old May 14, 2004 | 12:36 PM
Edward Goodell's Avatar
If money is the main problem then you should check out rpm outlet. they sell Lakewood traction bars for 95 bucks and they work excellent.
