What are boost bypass and FTVB?
Old May 12, 2004 | 11:58 AM
Shades9323's Avatar
What are they and what do they do for you? Are they easy to do? Are they expensive?
Old May 12, 2004 | 12:22 PM
whip's Avatar
The boost bypass is a solenoid that dumps your boost in certain situations. LIke if you over rev during a burnout. You can either unplug the solenoid, which is a touchy subject, some people say it may throw a check engine light, some say it wont. Or you can buy the boost bypass kit. Or you can do a search on it, and find out the parts you need, spend 3 dollars on fittings and make your own. Very easy once you find the pictures. (I hate the search button, maybe you can find it!) Good mod, do it!
FTVB....Factory Tech (The guy that sells it) Valve body. Basically a tuned shift kit for your truck. Very good mod. It will make your truck shift firmer under part throttle, and bark the ***** out of your tires on the 1-2 shift under hard throttle. It will work well with a chipped truck. Good mod...personal preference, some people don't like the firm shifts...I would reccomend going for a drive with someone who has done this. Easy to do if you have a lift and know what you are looking at. Drop the tranny pan...remove old valve body, install new one, done.
almost forgot prices....boost bypass. Anywhere from free (most tuners will throw it in with your order if you ask nice) to three dollars at the parts store, to 25 dollars advertised price from tuners.
FTVB I think they are around 200 bucks, sometimes you can find them on "monthly specials" for cheaper.
Hope this helps!
Old May 12, 2004 | 12:35 PM
wydopnthrtl's Avatar
Whip summed it up very well.
btw: The part throttle shifts are perfect after you get a converter. Or at least I think so.
Rich
Old May 12, 2004 | 12:57 PM
StruckBy99's Avatar
There is only one downside to installing the FTVB yourself. You need an inch pound torque wrench for the bolts/nuts holding the valve body in. Not really a downside I guess, but adds about $75 to the install if you dont already have one.
Jason
Old May 12, 2004 | 02:58 PM
Rob_02Lightning's Avatar
Jason
I don't use no stinking Torque Wrench, it's all in the wrist
But then again I'm the guy that puts Never-Seeze on the Plugs,
and is still driving around with the wrong tranny fluid
Old May 12, 2004 | 03:53 PM
brain bypass's Avatar
Jason
i just bought the inch-pound from sears, used it to torque the valve body in, and exchanged it for a foot-pound wrench. if you already have a ft.-lb. one, then just return it.
Old May 12, 2004 | 05:06 PM
Tim Skelton's Avatar
What is the button and is it free?
Old May 12, 2004 | 05:15 PM
Fast Gator's Avatar
Is it like the button?
Old May 12, 2004 | 05:23 PM
grinomyte's Avatar
in lb wrench is 75 bucks?
Ive been looking for one and can never find it.
Old May 12, 2004 | 06:09 PM
StruckBy99's Avatar
Look here.
Jason
Old May 12, 2004 | 06:34 PM
Now take your seat, please.
Old May 12, 2004 | 08:31 PM
Fast Gator's Avatar
LMMFAO
Old May 12, 2004 | 08:36 PM
grinomyte's Avatar
thanks jason.
doesnt ftvb ask for 11 in lbs or something like that?
Old May 12, 2004 | 08:48 PM
Shades9323's Avatar
It is free. But why would I waste an hour sifting through threads that just mention the words and not explain them, when it will take someone 2 minutes to explain it for me.
Old May 12, 2004 | 09:13 PM
StruckBy99's Avatar
thanks jason.
80-100 inch lbs.
Jason
