Traction Bar Questions & Problem
Old May 11, 2004 | 03:29 PM
SVTJAY's Avatar
I’m running the Steeda Axle Relocation Kit on the rear of my L. I’m looking for a traction bar set up that will work the spring under set up I have. Anyone have any ideas? I like the style of the Rancho & LFP bars but no one can tell me if they will work with my application.
Old May 12, 2004 | 06:45 PM
SVTJAY's Avatar
No one has any suggestions?
Old May 12, 2004 | 09:48 PM
Tim Skelton's Avatar
Yes, I have two.
1. Explain what a Steeda relocation kit is.
2. Wait longer than three hours before stressing out about not getting a response.
Old May 12, 2004 | 09:54 PM
MISTERgadget's Avatar
The steeda relocation kit moves the axle from under the leaf spring to over the leaf spring, netting about 4" drop in the process.
Old May 12, 2004 | 10:02 PM
SVTJAY's Avatar
Just moving the axle to the top of the stock springs would result in a 6" drop, the Steeda kits comes with new leafs as well, result is approx 3" drop on a lightning.
look at the dates in the posts... posted 1 day and 3 hours ago.
Here is what the ride height looks like
The kit did eliminate all wheel hop that I was experiencing when stock.
Old May 12, 2004 | 10:09 PM
. . . look at the dates in the posts... posted 1 day and 3 hours ago. . .
Then may I offer myself a suggestion?
1. Read first, then write.
Sorry.
Old May 12, 2004 | 10:16 PM
SVTJAY's Avatar
Sorry.
It’s ok... BTW many of your web site articles have helped out a lot thanks!!!!
Old May 17, 2004 | 02:38 PM
PWR_WHLS's Avatar
Well - if all that happened was the leafs were moved from "over" to "under" -- then most standard traction bar setup's would work.
Call a tooner and get measurements on how the pieces connect and the dimensions.
How do you like the kit ... how big of a different was it?
Good Luck,
John
