TB Question
Old May 11, 2004 | 10:25 AM
WarEagle's Avatar
Question TB Question
I had my throttle body removed and cleaned because it needed it. I was expecting better or at least the same throttle response however.... it is not as good as before it was cleaned. The boost guage seeems to climb but the acceleration seems slower. From about a 40 MPH punch it seems OK. Any ideas? TPS? I also had my fuel filter changed at the same time. Thanks in advance for the answers.
WarEagle
Old May 11, 2004 | 10:54 AM
evo's Avatar
evo
Check your TPS voltage. I set mine at .98V
Old May 11, 2004 | 11:38 AM
yysenhimer's Avatar
Originally posted by evo
Check your TPS voltage. I set mine at .098V
I think you mean 0.980V or 980 mV.
Old May 11, 2004 | 11:41 AM
Mart Man 03 L's Avatar
I'd say check the TPS voltage also. It should be 0.96V to 0.98V.
Old May 11, 2004 | 11:55 AM
D Davis's Avatar
Stupid Question, what should the Idle be at when setting TBS voltage?, or doesn't that affect it?
I know mine was at 1.25v And couldn't get it below 1.23v, I think my Idle is around 800rpm
jarmstro's Avatar
Re: TB Question
WarEagle
Did you remove the TPS when you cleaned your throttle body? If not you can rule out the TPS, however I would check it anyway.
Is this a stock TB? Make sure the blades are opening completely and the throttle cable is not binding any where.
Old May 11, 2004 | 03:56 PM
evo's Avatar
evo
Your right I miss typed.
Old May 11, 2004 | 04:02 PM
evo's Avatar
evo
I had to drill the screw holes larger to get enough play to adjust it. I set it with just the Key on. Not running
