Rear end, want it firmer
Old May 10, 2004 | 05:45 PM
Crued's Avatar
As with all our ladies, we want them to have firm rear ends. I noticed this weekend after sliding the rear end out and recovering, that the L is just wayyyy too loose back there. How can I stiffen her up without going crazy.
I have 2" shackles in back, with SoCal endlinks. 1" springs up front and shortened endlinks.
Old May 10, 2004 | 06:08 PM
MadNess's Avatar
QA1 adjustable shocks those mothers on the tightest setting will jar the crap out of you...
Old May 10, 2004 | 06:33 PM
LatemodelRacer2's Avatar
wont a panhard bar help this problem.
Old May 10, 2004 | 11:06 PM
AmoJohnny's Avatar
New suspension like Roush or Hotchkis
Old May 11, 2004 | 01:29 AM
Tim Skelton's Avatar
Yes, but it is not the first place that I would look.
Putting on Roush or Hotchkis leafs (stiffer) will probably make the problem worse. Stiffer front springs would help, though.
I would try tire pressure first. It's free and makes a huge difference.
With the Hotchkis full meal deal and about 4 lbs more in the front than the rear, I get just the right amount of understeer to be forgiving and no oversteer in all but the most extreme conditions.
Old May 11, 2004 | 09:24 AM
Crued's Avatar
ok...... so where would one start?
Old May 11, 2004 | 09:27 AM
Old May 11, 2004 | 09:33 AM
i think he wants you to try some stuff with air pressure before you spend any money on it.
Old May 11, 2004 | 09:50 AM
unclemole's Avatar
Judicious throttle control.
If you're complaining about fish-tailing under hard acceleration.
How about traction bars?
Old May 11, 2004 | 10:14 AM
Crued's Avatar
i don't think i explained the problem correctly. i think most people are thinking i'm talking about 'fishtailing', or the back end swining out . what i'm talking about is after correcting fishtailing, there's a massive 'rocking' back and forth of the rear end. *this* is what i want to stiffen up. so that when you correct a fishtail, the truck responds as a solid unit rather than a jello log.
Old May 11, 2004 | 10:17 AM
so you are geting a lot of left to right play in the rear end? Then the phanard bar like i mentioned should keep the rear end from moving back and forth. Might even try some Hotchis sway bars to prevent the body roll.
Old May 11, 2004 | 12:42 PM
I agree with the above. It is that kind of thing that the panhard will help with.
And, of course, stiffer springs/shocks/anti-sways will also help.
Old May 11, 2004 | 05:17 PM
oldfrmtrk's Avatar
I used these "http://www.activesuspension.com/index.htm"
They worked for me. However I will still plan to add Ranchero style bars to the rear!
