Track Times
Old May 9, 2004 | 07:41 PM
SVTJAY's Avatar
Track Times
Finally made a trip to the drag strip on saturday here are the results. Does this seem about right for the mods?
60 1.986
330 6.781
1/8 8.842
1000 11.106
1/4 13.293
MPH 103.414
EDIT: Air temp was approx 75 degrees
Mods are
2000 L
4lbs Lower
90mm Mass Air
JLP Air Induction
C&L True Flow Inlet Pipe
Bassani X Pipe, Spintech Mufflers
Boost Bypass
Predator Tuned by RTWD
Old May 9, 2004 | 10:37 PM
DEIMATT's Avatar
Sounds like your doing good specially out in Cally!!
Nice job!!
Old May 9, 2004 | 11:23 PM
Don's Bolt's Avatar
You might be off a little but your pretty much where you should be. What was the temp on that run?? If it was hot you are where you should be.
What is killing you is that 60 foot time, get that down to a 1.7 and you might be knocking on a 12 second run.
Old May 9, 2004 | 11:25 PM
SVTJAY's Avatar
air temp was around 75 degrees
I was under the impression that a 60 ft 2.0 and under on the f1's was good? is this not correct?
Old May 9, 2004 | 11:38 PM
Don's Bolt's Avatar
well it all depends on the way the track is prepped.
Sounds like you had poor track prep.
I have seen 1.65 60 foot times on a really good prepped track.
Old May 10, 2004 | 01:00 AM
StruckBy99's Avatar
A 1.65 on F1's??
That's EXCELLENT track prep!
