04 drop shackles
Old May 7, 2004 | 05:49 PM
RGCBSHRTY#1's Avatar
04 drop shackles
Will the DJM drop shackles for the standard F150 work on my 04 L?
Old May 7, 2004 | 05:55 PM
brain bypass's Avatar
yes, but you want at least 3", and it will be 1" less drop than advertised for the regular 150
Old May 7, 2004 | 06:09 PM
AmoJohnny's Avatar
I got 2" DJM's for my 03. It did lower it a little bit. It COULD use more of a drop (ill be gettin hotckis in the summer), but it gets iffy and you might need shimwork and alignment if you drop it more.
Old May 7, 2004 | 10:04 PM
Mart Man 03 L's Avatar
Use the JLP shackle. It's only $109 and if you use the top holes your L should sit almost level. When you install them, flip the factory shim so it points the opposite direction and you wont have any vibration problems.
That's what I did to my '03.
