built motor comming!!!!
Old May 4, 2004 | 06:11 PM
LeoGSVT's Avatar
truck didnt go boom, but ive got the money together to go ahead and build my truck...but i wanted to ask a few Q's to the pros who have been down this road...and what are some do's and don'ts...well here is my list of parts....
-Built lower
-55lb injectors
-Full exhaust (w/ long tubes)
-Heat Exchanger
-255lph pumps
-FTVB
i already have a KB sitting on top of my motor so i will be go to go boost wise...allthough i run 15lbs i wouldnt mind bumping it up a few lbs...so here is my Q.
once i get all this put together do i have the green light to take off my 4lb lower and swap it to an 8lb lower....i wanna run somwhere in the 18-19lb range...or can i go more? with my new setup????
since im in Florida...i go to a shop in Orlando (lugo performance) where a tuner for diablo comes out and tunes some L's....i was wondereing weather to stick with him or maybe go to a L tuner who knows more about high hp trucks..maybe REM?? any recomendations????
also is there anything i might want to add/remove from my list of parts from above....my current mods are below...thanks guys
4lb lower
KB w/ 3.5 upper
single blade T/B
NGK Br7's
170thermo
Rancho bars
90mm mass air/12'' filter/volant inlet boot/custom ram air
hoosier slicks
diablo chip
Old May 6, 2004 | 01:38 PM
LeoGSVT's Avatar
anybody????
Old May 6, 2004 | 01:54 PM
SonicLightning's Avatar
Willie's reputation is unquestionable, however lugo's is.
Old May 6, 2004 | 01:56 PM
2002Bolt's Avatar
if i were you
I would stick with lugo, they are a pretty well respected tuner. I went to a mustang shop in orange park and had some parts on my lightning put on, and they had a black lightning with a kenne bell on it and they were taking it to lugo, they owner of the shop, Sean, said that he was a good tuner. If you havent had any problems with your old tune why not go back. FYI i have heard some bad things about REM and their tuning.
Old May 6, 2004 | 02:11 PM
bstabler's Avatar
Originally posted by LeoGSVT
anybody????
I would Deff go to R.E.M. The motors they are producing are awsome. I will have some good numbers to post after breakin and I am only running the eaton. With the KB and what you are doing, you shold be low 11's and Poss 10's. The motors they are now building are very smooth and quiet!!!!
Old May 6, 2004 | 02:29 PM
MISTERgadget's Avatar
Doesn't Mustang Specialties build the REM motors?
I would stick with having Willie form Diablo tune it, unless you want a Jerry File, you can email me for more info on that.
Old May 6, 2004 | 03:07 PM
LeoGSVT's Avatar
thanks guys...yeah i will probably order my stuff from REM...ive heard they produce good products...and i was actually at lugo when they tuned that Black L...made like 511rwhp @16psi...i just need a good installer...i know sean at Mustang Motorsports here in town and see if he can put it together for me for a good deal...thanks for the imput.....hope for mid-low 11's for now...my goal is 10's
Old May 6, 2004 | 07:17 PM
Johnny AC's Avatar
Thumbs up REM
Good luck Leo, I'm sure they'll take good care of you. I've had nothing but good things to say about their parts and service, John H
Old May 6, 2004 | 08:32 PM
jarmstro's Avatar
Talking
You shouldn't have any problems running an 8lb lower and 2lb upper once you get your engine. That's the combination I'm running with a JDM built engine and seeing 21lbs of boost with a Magnum Powers blower.
The MP has gotten me in the 1.5X short times now.
Old May 6, 2004 | 09:46 PM
band's Avatar
Re: built motor comming!!!!
ARP Head studs for 20+ lbs of boost from what I have gathered..
