WASP Blower, dyno comparisons
Old Apr 28, 2004 | 10:01 PM
tallimeca's Avatar
hmm
Dale, your right, i didn't even notice that. To be honest, i have no idea what the difference is but there are plenty of people who do on here. Anyone wanna help me out here??
Old Apr 28, 2004 | 10:15 PM
Bad as L's Avatar
You might have a better runnin truck than you think
Old Apr 28, 2004 | 11:22 PM
RollinLimp2001's Avatar
Originally posted by Bad as L
Correct me if I'm wrong but the JDM sheet says STD correction and the latest test shows SAE correction. I don't know how you could compare the two.
Dale
That's exactly what I was going to say. If you go get your truck pulled with STD numbers again I don't think you will see as much of a loss of torque if any and probably the usual 20-30 pick up in horsepower from a ported blower. I think the difference between my SAE and STD was like 15hp or so...of course thats affected by weather and such, but just to give you an example...
Old Apr 28, 2004 | 11:23 PM
yysenhimer's Avatar
Re: hmm
Originally posted by tallimeca
If anything, the numbers should be significantly higher by leaning out the mix that much. I'm going to have it richened up a little bit. Now, these pulls were done on my street side, so i'd be pulling more power on my strip side. I have a somewhat conservative tune, well, untill it leaned out.
That's kind of what I was saying.
Dale
The after would show less of a gain. I'm sure you can call the dyno place and have them send you one of the runs using STD correction. Most places I know of save all of the runs. Or call JDM and have them send SAE corrected runs.
Old Apr 28, 2004 | 11:33 PM
Twisted99's Avatar
I made
Before
384HP@ 4800 RPM and 477FT #'s @ 3600 RPM @ A/F 0f 10.0 @ 84 degrees.....STD
AFTER
408 HP@ 4600 RPM and 497 FT #'s @ 3500 RPM @ A/F of 11.5 @ 72 degees....
STD
AFTER
396HP@4600 RPM and 483 FT #'s @ 3500 RPM @ A/F 11.5 @ 72 degrees...
SAE
Same Dyno with Tailpipe sniffer each pull..
The After pull was the highest of the day but was also run after 6 consecutive pulls...in other words heat soaked.
The first pull was the third pull and the highest of that day.....so maybe heat was not as much a factor....
Old Apr 29, 2004 | 06:59 AM
Fast Gator's Avatar
Here's my dyno sheet of the before and after pulls with a Apten port job. Same dyno, 5 days apart, similar weather conditions.
Spinning the everloving chit out of it
You mileage may vary
Gained "alittle" hp and didn't lose any tq
Old Apr 29, 2004 | 07:21 AM
Rob_02Lightning's Avatar
YOUR GONNA NEED ALL YOU CAN MUSTER
NEXT TIME WE MEET ON THE 1320
Old Apr 29, 2004 | 11:06 AM
blackjack's Avatar
Peak numbers
It seems to me that peak numbers are not what are telling the story with the ported blower. Compare the before and after curves above 3500 RPM. Does anyone have any before and after results on the truck that has head/cams??
Scott
Old Apr 29, 2004 | 05:51 PM
Fast Gator's Avatar
with your reaction times, I could beat you with the LTD
Old Apr 29, 2004 | 08:20 PM
Ok you got me there Buddy, you DO cut a mean light,
and I do have to factor that in to the next run.
That why I will be pushing my Baby with the most stress
she's ever had thrown at her next time.
Hey what the hell,
for You Gator, I'll take that risk
Old Apr 29, 2004 | 09:03 PM
tallimeca's Avatar
UPDATE
OK, so what i'm seeing is the SAE numbers will always be a bit lower. Where my baseline pull was STD numbers, and the numbers for the ported blower pull were SAE, there is no real comparrison. I'm going to call the dyno tomorrow do see if they can convert my chart to STD correction or not. All in all from what i read, STD numbers are usually highter by at least 4%. If this is true, and we use 4%(don't know and not saying this is how it is for sure).....this would be the difference.
Before 416/ 522, After 443/521.
If that's the case, I would be very happy, and like everyone is saying, spinning it faster would show mower gains, so i'm thinking maybe time for an upper pulley swap.
I'll call the dyno tomorrow and see what happens.
Old Apr 30, 2004 | 12:03 PM
tallimeca's Avatar
bump
just wanted to bump this up so anyone who read it could see the update
Old Apr 30, 2004 | 03:45 PM
whip's Avatar
Re: UPDATE
[QUOTE]Originally posted by tallimeca
[B]
If that's the case, I would be very happy, and like everyone is saying, spinning it faster would show mower gains, [QUOTE]
Don...I know the hardware store is probably booming right now with grass growing and trees budding, but I don't think your ported blower has anything to do with MOWER gains!!!!!!!!
Old May 1, 2004 | 07:30 AM
tallimeca's Avatar
hahaha
i was on my way out to cut the crass when i posted that!!!!!!
Old May 1, 2004 | 08:09 AM
E-luzion's Avatar
Yo Don... i changed to STD 432/564 smoothing 5!!!!!!!!!! Still dont understand how your hp is higher....
