is there a how-to on engine/ i/c coolant change
Old Apr 24, 2004 | 06:04 PM
93redcobra's Avatar
want to change the coolant on the L any tips? what mix should i use?
Old Apr 24, 2004 | 07:03 PM
BuiltL's Avatar
Use 50/50 water/anti-freeze mix. For the IC just open the pet**** on the heat exchanger and let it drain out. For the engine cooling system open the pet**** on the radiator. Then you need to pull out the plug on the driverside of the block and let that drain. The plug is above the oil filter.
Zach
